587,931 active members*
3,858 visitors online*
IndustryArena Forum > CAM Software > EdgeCam > OKUMA LB300M post processor
Results 1 to 2 of 2
    Apr 2014
    18
    hi guys, i'm new to this forum. (i'm italian,sorry for my english)
    I'm trying to compile with code wizard the post processor for my machines.
    I have a few doubts about macro use in the code constructor, about the variable #MOVE the is the same for more tokens, and the use of variable #FUNNY
    this is post processor for okuma lathes with c axis.
    everything works quite well except for a few details and i need help.
    the fist problem is the position x and z in the tool change.
    usually the call is G0 T101 M8 G95 G96 S300 X100 Z4 M4 M63
    (x y z and c in the toolchange that i use are the positioning for the following processing)
    this is the code constructor
    ;CODE:#USER2=#XMOVE
    ;CODE:#USER3=#ZMOVE
    ;CODE:#USER9=POSITION
    ;CODE:$USER=VNRPN
    ;CODE:$USER1=VNSRX
    ;CODE:$USER2=VNSRZ
    ;CODE:
    (T[USER-9]. [TOOLDESCR])
    (SU [HOLDER_TYPE])
    ;CODE:
    ;CODE:* set raggio utensile per compensazione
    [USER-STRING-1][LBRKT][USER-9][RBRKT]=[<+>NOSERAD-X] [USER-STRING-2][LBRKT][USER-9][RBRKT]=[<+>NOSERAD-Z] [USER-STRING][LBRKT][USER-9][RBRKT]=[<+>QUADRANT]
    ;CODE:
    [DELETE][BLKNUM][<C>RAPIDGCODE][TURRETNO][CRC REGISTER][COOLANT][<C>FEEDMODEGCODE][<C>CSSGCODE][<C>SPEED][USER-2][USER-3][<C>SPINDIR][GEARMCODE] M63
    [DELETE][BLKNUM][SAFEBLKNUM]
    and this is the output of post processor with all procedure trace
    M90 M216
    * MACRO 52 (NOCYCLE) : STARTMAIN
    * MACRO 193 (EXECUTIVE) : TURNING/AXIAL/RADIAL MODE
    * MACRO 15 (EXECUTIVE) : TOOLCHANGE
    * > PMACRO-15
    * > PT_MODIFIERS
    * > PT_THROUGH_COOL
    * > PT_SET_COOLANT_FLOW
    * > PT_SET_COOLANT_TAPS
    * > GET_QUADRANT
    * > PT_LOAD_NEXT
    * > PT_TLO_SET
    * > PT_GET-THRXZ
    * > PT_INDEX_TURRET
    * > PMACRO-252
    * > PT_SPINDLE
    * > PT_MTH_SFM_TO_RPM
    * > PT_GEAR_MCODE
    * CURRENT RPM=830 CAM SPEED= NEXTSPEED=300
    * CSS RADIUS
    * MODES #CSS=1 CAXIS=0
    * GEAR SPEED RANGE 50 TO 1100
    * SPINDLE SPEED RANGE TO 3800
    * > PT_TC_REFERENCE_SHIFT
    * > PT_SET_TOOL_TURN
    * > PT_ROUND_VALUE
    * > PT_ROUND_VALUE
    * CURRENT CPL POSITION X127 Z790
    * CURRENT MOVE SET AT X254 Z790
    * > CALL_TC
    ***** CODE CONSTRUCTOR : FIRST TOOLCHANGE *****
    * > PT_BINC
    * > PT_C_STATUS
    G0 X800 Z800 M109
    * > PT_BINC
    * > PT_GEAR_MCODE
    * CURRENT RPM=3800 CAM SPEED= NEXTSPEED=300
    * CSS RADIUS
    * GEAR SPEED RANGE 1101 TO 3800
    G50 S3800
    ***** CODE CONSTRUCTOR : CORE TOOLCHANGE *****
    (T1. MWLNL-2525M-08)
    (SU )
    VNSRX[1]=.8 VNSRZ[1]=.8 VNRPN[1]=3
    * > PT_BINC
    * > PT_SPINDLE
    * > PT_GEAR_MCODE
    * CSS RADIUS
    * > PT_SPINDLE
    * > PT_GEAR_MCODE
    * CSS RADIUS
    G0 T101 M8 G95 G96 S300 X254 Z790 M3 M41 M63
    * > PT_BINC
    * > PT_SBINC
    NT1
    * > PT_SBINC
    * > HOLD
    * MACRO 4 (EXECUTIVE) : ROUGH TURN AREA CLEARANCE
    * > PMACRO-4
    * > RT_VARIABLES
    * > DIVERT_CYCLSUB_RAPID
    * > PT_OUTPUT_RAPID
    * > EVALUATE_MOVE
    * > PT_FIX-STUB
    * > PT_ROUND_VALUE
    * > PT_ROUND_VALUE
    * > PT_CONTROL_FEEDTYPE
    * > PT_SET_SPEED
    * CAM COORDINATES X Y Z C0 R
    * MACHINE COORDINATES X254 Y0 Z4 CMAIN
    * MOVE EVALUATION CODE #MOVE=4
    * MILLMODE=0 CAXIS=0 #DIAM=2
    * > PT_RAPID_AFTER_TOOLCHANGE
    ***** CODE CONSTRUCTOR : RAPID AFTER TOOLCHANGE *****
    * > HOLD
    ***** CODE CONSTRUCTOR : WARNINGS *****
    * WARNING - FEED LINK TYPE NOT AVAILABLE IN CONTROLLER CYCLE !
    * > PT_OUTPUT_RAPID
    * > EVALUATE_MOVE
    * > PT_FIX-STUB
    * > PT_ROUND_VALUE
    * > PT_ROUND_VALUE
    * > PT_SET_SPEED
    * MACHINE COORDINATES X115 Y0 Z4 CMAIN
    * MOVE EVALUATION CODE #MOVE=1
    ***** CODE CONSTRUCTOR : RAPID MOVE *****
    * > PT_BINC
    X115 Z4 (i want this coordinate in the toolchange)
    * > HOLD
    * > PT_MTH_STOCK_OFFSETS
    * > PT_SET_SPEED
    ***** CODE CONSTRUCTOR : ROUGH TURN CYCLE *****
    * > PT_BINC
    G85 NLAP1 D5 U.3 W.21 F.3
    Apr 2014
    18
    Re: OKUMA LB300M post processor
    Hi, guys,
    how can i force positive value output of the variables [#TNRX=65] and [#TNRZ=66] in the block code inside <>?
    ;CODE: %PROCEDURE=COMP_VARIABLES
    ; * Variabili compensazione raggio utensile
    ;CODE: %IF $CONDEBUG=N @NO_CON-DEBUG
    ;CODE: <***** Code Constructor : Compensation variables *****>
    ;CODE: @NO_CON-DEBUG
    ;CODE: %IF #DRIVENTOOL=#TOOLDRIVEN @DRIVEN
    ;CODE: %IF #DRIVENTOOL=#TOOLSTATIC @TURN
    ;CODE: @TURN
    ;CODE:
    <VNSRX{091}[POSITION=13]{093}=[#TNRX=65] VNSRZ{091}[POSITION=13]{093}=[#TNRZ=66] VNRPN{091}[POSITION=13]{093}=[#QUAD=67]>
    ;CODE: %GOTO @OUT
    ;CODE: @DRIVEN
    ;CODE: %IF CAXIS=1 @AXIAL
    ;CODE: %IF CAXIS=2 @RADIAL
    ;CODE: @AXIAL
    ;CODE:
    <VNSRX{091}[POSITION=13]{093}=[TOOLRAD=61] VNRPN{091}[POSITION=13]{093}=[#QUAD=67]>
    ;CODE: %GOTO @OUT
    ;CODE: @RADIAL
    ;CODE:
    <VNSRZ{091}[POSITION=13]{093}=[TOOLRAD=61] VNRPN{091}[POSITION=13]{093}=[#QUAD=67]>
    ;CODE: @OUT
    ;CODE:%ENDM
  1. 4-Axis okuma post processor
    By ramirezdono in forum PowerMILL
    Last Post: 03-07-2015, 05:52 AM
  2. Okuma OSP 5000-MG Post Processor
    By BB72CAMARO in forum Dolphin CAD/CAM
    Last Post: 02-21-2013, 04:32 PM
  3. 4th axis post processor for okuma
    By jonatclifty in forum Mastercam
    Last Post: 06-27-2012, 05:57 PM
  4. edgecam post processor for okuma cnc mill
    By Wheels20 in forum Okuma
    Last Post: 08-03-2009, 04:09 AM
