Re: Are Twin spindle Twin turret lathes as complex as they look?
We have several & the problem I run into is holding endmills with the live tooling
hi jmk, what about changing the arbor inside all live toolholders, so to suit 32 instead of 25 ? i guess the motor can deliver enough power
try also bearing nuts ![Smile](images/smilies/smile.png)
I am aware of preci-flex options of endmill holders
far as i know, preci-flex is a quick change system, and such systems are not as rigid as integral ones
however, even inside an 32 or 40, if milling operation has high specs, the endmill may slip inside the collet
if you wish to avoid this, maybe you should try to order some custom arbors at shunk, that use tendo-aviation approach / kindly
