587,952 active members*
3,675 visitors online*
Results 1 to 7 of 7
    Dec 2003
    24220
    Question Hirth Coupling Source?
    Looking for a source of Hirth couplings in Canada, I have only found one, Voith of Germany.
    Anyone have an idea what the average cost is? 120mm dia?
    Al.
    Albert E.
    Jul 2006
    1256
    Spain?Tedisa -- Company
    Home Page check E-bay store.
    Larry
    L GALILEO THE EPOXY SURFACE PLATE IS FLAT
    Dec 2003
    24220
    Thanks larry, I found that Voith have offices in Canada, so I may find success there.
    Al.
    Albert E.
    Jun 2012
    Al.
    Dear AI,
    I see you already contacted Voith. In case you need another source, you have a very good choice in Tedisa (Tedisa | High precision Hirth couplings), as Larry says. Even if they have no office in Canada, you can contact them directly without problem.
    If you still need an office, they have one in the USA (50 mm to 1500 mm).
    REgards,
    Andy
    Dec 2003
    24220
    Quote Originally Posted by Andrew74 View Post
    Dear AI,
    Voith acknowledged my email but never did get back to me.
    I will keep this on file in case I need another in the future.
    Al.
    Albert E.
    Jul 2005
    12177
    I recognise this is a year (or more) old thread but I wondered if you did get some contacts. This is probably the closest source of Hirth couplings: TAC Rockford
    I started looking for information about Hirth couplings a while ago because I was planning on using them for a new product line I had in mind. They are quite fascinating and not that difficult to make if you are only worried about +/-0.001" tolerances. But they are a bit tedious to program by hand.
    Dec 2003
    24220
    The project got dropped but for some reason the Co's I contacted did not reply?
    I will make a note of the one posted.
    Thanks.
    Al.
    Albert E.
  1. Looking for shaft coupling
    By lilimike in forum DIY CNC Router Table Machines
    Last Post: 08-29-2015, 08:02 AM
  2. Coupling....is this close enough?
    By HereinCS in forum DIY CNC Router Table Machines
    Last Post: 07-28-2010, 04:10 PM
  3. Rigid Coupling Vs. Flex Coupling
    By Johnsnd in forum DIY CNC Router Table Machines
    Last Post: 05-30-2009, 03:25 PM
  4. Flexible coupling
    By Buzz9075 in forum DIY CNC Router Table Machines
    Last Post: 01-12-2007, 06:57 PM
  5. Coupling Help
    By Gorillakilla in forum MetalWork Discussion
    Last Post: 01-24-2006, 05:04 PM
