There is a test system that is in the Fanuc training manual that shows how to stop the red LED fault on the input unit from shutting the power supply down, but it has to be done with caution as obviously something caused the shut down and jumpering it out does not remove the fault, so take care if this method is used.
The problem is there is many types of Input units, but the basic premise is the same.
The one I was shown was to jumper out the P1 & P2 pins to hold in RY1 on.
One problem in your case is that if the fault happens momentarily and causes the shut down, the fault has come and gone when you manage to jumper it out.
Al.
Albert E.
