587,275 active members*
3,631 visitors online*
IndustryArena Forum > CNC Electronics > Stepper Motors / Drives > Stepper Motor Controller Questions
Results 1 to 11 of 11
    Aug 2009
    392
    New here, hope this is the right section
    Anyways, I'm wanting to make a small scale CNC machine, which I already have designed and am in the process of constructing it. I need a stepper motor controller, that will be running 3 unipolar stepper motors. I don't mind building it myself if I need to. I basically need the most inexpensive controller possible that is capable of doing this. I was looking at the Linistepper, as well as one on www.instructables.com (located HERE), but I'm just looking for some input. Thanks
    Jun 2007
    73
    I have no experience using other unipolar boards than the HCNCPro from HobbyCNC. It is an "All-In-One" board with 3 (or 4) drivers and parallel port connection. I can just say that I have been very satisfied with its performance during the years and it is cheap.
    You have to assemble it youself, but it's fairly easy and comes with well explained intructions how to do it. You will be able to join a specific user group where you can get all the help you want.
    If you have the money, another option would be the G540 from Geckodrive. It is a 4 axis drive with BOB like the HCNC. It is a bi-polar drive, but I think that your steppers would hook up with it. (you could tell us which steppers you have). For several reasons, its performance vs price is really hard to beat. Especially now where GD have their annual costumer appreciation sale.
    Good luck
    Brian
    Aug 2009
    392
    Alright, thank you very much for your input. I like the look of the HCNCPro. Not to sound cheap, but is there any other more inexpensive options? This is my first CNC, so I don't need anything major, and just want something inexpensive to get it operational before I work on upgrading different components of it.
    Aug 2009
    392
    I have been looking around a little bit, and stumbled across PMinMO.com . I was looking at the Pic3, the Tach42, and This (I didn't see a name for it). Any of those any good?
    Jun 2007
    73
    I can't/won't recommend other boards, for the simple reason that I haven't tested them myself. I hope that others will come up with some inputs.
    Maybe it's easier if you tell us something about the machine you are building and what you want to do with it?
    E.G.
    - Dimensions of the machine
    - Weight
    - Linear guidance
    - By which mechanism is it driven (screw or maybe belt?) Pitch?
    I think that the best way to advise you, is to know what we are dealing with and what your needs are. It's all about happiness over a longer term.
    After a short while you will become addicted to CNC, so it's better to get it "more right" the first time.
    Aug 2009
    392
    Quote Originally Posted by CNCDevil View Post
    Alright, that's doable It's a very small machine, with the entire footprint less than 2' by 2'. I will be just making random odds and ends; Belt Buckles, PCB Boards, and the like. I would like for it to be capable of machining Aluminum. The x- and y- axes will have their rails attached to the base. I don't really know how to explain it very well, if there's anything you need to know that I missed just say so
    I'll assume you mean the cutting area I'm not at home (which is where my design is), but I believe the cutting surface is only about 8"-9" by 11"-12".
    - Weight
    I am not 100% what the weight will be, but it won't be much, as I designed it with the intentions of keeping it light-weight. I believe the motors I'm looking at are about 130oz-in each, but again, most of my information is at home.
    - Linear guidance
    Noobiness kickin' in. What does that mean?
    It will be screw driven. I can't remember the pitch, as, yet again, information is at home!
    That's completely understandable I just want to get something that's operational that I can practice on, and get my basic skills developed before I convince myself to put more money into it.
    Jun 2007
    73
    When you get back home, write a post with the parts you've missed, including the materials you made the machine of. If you have a drawing it would be nice.
    Machining aluminium you say? We want to discuss this subject when we know more.
    Liniar guidance is the rails for the axis' you mentioned. What type are they?
    Aug 2009
    392
    Okay, thanks for all the help thus far. Once I have the information you seek I'll be sure to write a nice detailed post with some pictures of the design
    Aug 2009
    392
    Also, is it possible to get this to work via USB, or do I need a parallel port for most applications? The reason I ask is because I'm placing an order in a few days, and I'm wondering whether or not to order a PCI Parallel port card, as my MoBo I'm ordering does not have one.
    Jun 2007
    73
    You should get it.
    There is a possibillity to use an USB connection, but at this moment it's not an option for you.
    Aug 2009
    392
    You should get it.
    Okay, thanks
  1. Stepper Motor Controller Design Questions
    By casslan in forum Stepper Motors / Drives
    Last Post: 08-10-2009, 04:11 PM
  2. Stepper controller/motor questions and advice request
    By Halfdone in forum CNC Machine Related Electronics
    Last Post: 12-09-2008, 12:00 AM
  3. Motor and controller questions
    By sYmbot2 in forum Community Club House
    Last Post: 10-11-2008, 06:43 AM
  4. Does any one know about this stepper motor controller
    By starCNC in forum DIY CNC Router Table Machines
    Last Post: 02-11-2007, 04:33 PM
  5. Stepper controller questions
    By petec in forum CNC Machine Related Electronics
    Last Post: 04-27-2004, 01:15 AM
