587,821 active members*
2,757 visitors online*
Results 1 to 13 of 13
    Jun 2003
    15
    Help with 4th axis
    Hello
    I have been trying to load a sample gcode file from a demo version of
    CNCWrapper V2. into Flashcut 2. The tool path does not display properly.Instead of text being wrapped around the X axis it displays as just lines in the X-Z plane.
    I have check marked the box for A axis in the machine tool configuration menu
    I also have Rotary selected for 4th axis type.
    The code was created to wrap around the X axis . It seems to me Flashcut does not recognize this and I cant find a option in the Config menu to choose axis of rotation.
    I would appreciate any help someone has to offer.
    Dave E
    Oct 2004
    188
    what version of flashcut are you using? i have never done any fourth axis but if you post your g-code file i will try it on mine to see. have you called flashcut they are usually very helpful. they spent a couple of hours on the phone with me back and fourth helping me figure out my usb to serial converter wasn't putting out the correct baudrate. but i will be happy to help
    Rob
    Jun 2003
    15
    Hello Rob
    Thanks for responding. This is a sample file from a conversion program called CNCWRAPPER. It opens up and displays correct in a demo version of Mach3.
    When I open it in Flascut (version 2.0.3 ) it displays as linier lines in the X-Z plane instead of text wrapped on a radius. I do get some varied results if I play with spacing in the code so I am thinking it might be a posting problem,or I am missing a setting. I say a setting problem because I can create the same results in Mach3 that I get in Flashcut by not checking the
    X axis in the "AXIS OF ROTATION" tab. I can not find any option like this in Flaschcut other then in the "MACHINE TOOL" set up screen you can choose A under "USE AXIS" and rotary under "4TH AXIS TYPE".
    I never thought to call Flashcut. I have owned there system for so long now that I figured I am not eligable for any free support anymore.
    Anyway thanks again for the offer to help, anything you can do will be apreciated.
    Dave
    N90G00X-0.1250A30.016Z1.2362
    N100G01Z0.9750F19.7
    N110G01X0.1249A29.343F39.4
    N120X-0.0625A28.218
    N130X0.1249A27.093
    N140X-0.1250A26.416
    N150G00Z1.2362
    N160G00A25.426
    N170G01Z0.9750F19.7
    N180G01X0.1249A24.753F39.4
    N190X-0.0625A23.628
    N200X0.1249A22.502
    N210X-0.1250A21.827
    N220G00Z1.2362
    N230G00A20.837
    N240G01Z0.9750F19.7
    N250G01X0.1249A20.164F39.4
    N260X-0.0625A19.039
    N270X0.1249A17.914
    N280X-0.1250A17.237
    N290G00Z1.2362
    N300G00X0.1208A16.174
    N310G01Z0.9750F19.7
    N320G01X0.1162F39.4
    N330A16.089
    N340X0.1208
    N350A16.174
    N360X0.1249A16.247
    N370X0.1125
    N380A16.022
    N390X0.1249
    N400A16.247
    N410G00Z1.2362
    N420G00X0.0624A12.782
    N430G01Z0.9750F19.7
    N440G01X0.0700A12.788F39.4
    N450X0.0771A12.807
    N460X0.0836A12.838
    N470X0.0897A12.879
    N480X0.0953A12.930
    N490X0.1004A12.989
    N500X0.1051A13.058
    N510X0.1092A13.133
    N520X0.1160A13.304
    N530X0.1209A13.493
    N540X0.1238A13.697
    N550X0.1248A13.907
    N560X0.1238A14.118
    N570X0.1209A14.321
    N580X0.1160A14.510
    N590X0.1129A14.598
    N600X0.1092A14.681
    N610X0.1051A14.757
    N620X0.1004A14.825
    N630X0.0953A14.885
    N640X0.0897A14.935
    N650X0.0836A14.976
    N660X0.0771A15.007
    N670X0.0700A15.027
    N680X0.0624A15.032
    N690X-0.0626
    N700X-0.0701A15.027
    N710X-0.0772A15.007
    N720X-0.0837A14.976
    N730X-0.0898A14.935
    N740X-0.0954A14.885
    N750X-0.1005A14.825
    N760X-0.1052A14.757
    N770X-0.1093A14.681
    N780X-0.1161A14.510
    N790X-0.1210A14.321
    N800X-0.1239A14.118
    N810X-0.1249A13.907
    N820X-0.1239A13.697
    N830X-0.1210A13.493
    N840X-0.1161A13.304
    N850X-0.1130A13.216
    N860X-0.1093A13.133
    N870X-0.1052A13.058
    N880X-0.1005A12.989
    N890X-0.0954A12.930
    N900X-0.0898A12.879
    N910X-0.0837A12.838
    N920X-0.0772A12.807
    N930X-0.0701A12.788
    N940X-0.0626A12.782
    N950G00Z1.2362
    N960G00X0.1249A11.792
    N970G01Z0.9750F19.7
    N980G01X-0.1250F39.4
    N990X0.1249A9.542
    N1000X-0.1250
    N1010G00Z1.2362
    N1020G00X0.0624A6.300
    N1030G01Z0.9750F19.7
    N1040G01X0.0700A6.307F39.4
    N1050X0.0771A6.325
    N1060X0.0836A6.356
    N1070X0.0897A6.397
    N1080X0.0953A6.448
    N1090X0.1004A6.509
    N1100X0.1051A6.577
    N1110X0.1092A6.653
    N1120X0.1160A6.822
    N1130X0.1209A7.013
    N1140X0.1238A7.216
    N1150X0.1248A7.427
    N1160X0.1238A7.636
    N1170X0.1209A7.839
    N1180X0.1160A8.030
    N1190X0.1129A8.118
    N1200X0.1092A8.199
    N1210X0.1051A8.275
    N1220X0.1004A8.343
    N1230X0.0953A8.404
    N1240X0.0897A8.455
    N1250X0.0836A8.496
    N1260X0.0771A8.527
    N1270X0.0700A8.545
    N1280X0.0624A8.552
    N1290X-0.0626
    N1300X-0.0701A8.545
    N1310X-0.0772A8.527
    N1320X-0.0837A8.496
    N1330X-0.0898A8.455
    N1340X-0.0954A8.404
    N1350X-0.1005A8.343
    N1360X-0.1052A8.275
    N1370X-0.1093A8.199
    N1380X-0.1161A8.030
    N1390X-0.1210A7.839
    N1400X-0.1239A7.636
    N1410X-0.1249A7.427
    N1420X-0.1239A7.216
    N1430X-0.1210A7.013
    N1440X-0.1161A6.822
    N1450X-0.1130A6.734
    N1460X-0.1093A6.653
    N1470X-0.1052A6.577
    N1480X-0.1005A6.509
    N1490X-0.0954A6.448
    N1500X-0.0898A6.397
    N1510X-0.0837A6.356
    N1520X-0.0772A6.325
    N1530X-0.0701A6.307
    N1540X-0.0626A6.300
    N1550G00Z1.2362
    N1560G00X-0.1250A5.310
    N1570G01Z0.9750F19.7
    N1580G01X0.1249A4.637F39.4
    N1590X-0.0625A3.512
    N1600X0.1249A2.387
    N1610X-0.1250A1.712
    N1620G00Z1.2362
    N1630G00X0.1249A0.722
    N1640G01Z0.9750F19.7
    N1650G01X-0.1250F39.4
    N1660A-0.414
    N1670X-0.1248A-0.524
    N1680X-0.1239A-0.630
    N1690X-0.1224A-0.734
    N1700X-0.1203A-0.835
    N1710X-0.1177A-0.932
    N1720X-0.1146A-1.024
    N1730X-0.1109A-1.111
    N1740X-0.1067A-1.190
    N1750X-0.1023A-1.265
    N1760X-0.0975A-1.332
    N1770X-0.0923A-1.390
    N1780X-0.0868A-1.438
    N1790X-0.0812A-1.478
    N1800X-0.0753A-1.505
    N1810X-0.0692A-1.523
    N1820X-0.0631A-1.528
    N1830X-0.0569A-1.523
    N1840X-0.0508A-1.507
    N1850X-0.0448A-1.480
    N1860X-0.0391A-1.440
    N1870X-0.0336A-1.393
    N1880X-0.0284A-1.334
    N1890X-0.0235A-1.265
    N1900X-0.0190A-1.188
    N1910X-0.0147A-1.109
    N1920X-0.0109A-1.022
    N1930X-0.0077A-0.929
    N1940X-0.0050A-0.830
    N1950X-0.0029A-0.727
    N1960X-0.0013A-0.621
    N1970X-0.0004A-0.513
    N1980X-0.0001A-0.401
    N1990A0.716
    N2000G00Z1.2362
    N2010G00X0.0000A-0.549
    N2020G01Z0.9750F19.7
    N2030G01X0.1249A-1.528F39.4
    N2040G00Z1.2362
    N2050G00A-2.518
    N2060G01Z0.9750F19.7
    N2070G01X-0.1250A-3.643F39.4
    N2080X0.1249A-4.768
    N2090G00Z1.2362
    N2100G00X0.0615A-2.822
    N2110G01Z0.9750F19.7
    N2120G01A-4.468F39.4
    N2130G00Z1.2362
    N2140G00X0.1249A-5.758
    N2150G01Z0.9750F19.7
    N2160G01X-0.1250F39.4
    N2170A-6.894
    N2180X-0.1248A-7.004
    N2190X-0.1239A-7.110
    N2200X-0.1224A-7.215
    N2210X-0.1203A-7.315
    N2220X-0.1177A-7.413
    N2230X-0.1146A-7.504
    N2240X-0.1109A-7.591
    N2250X-0.1067A-7.670
    N2260X-0.1023A-7.746
    N2270X-0.0975A-7.812
    N2280X-0.0923A-7.870
    N2290X-0.0868A-7.918
    N2300X-0.0812A-7.958
    N2310X-0.0753A-7.985
    N2320X-0.0692A-8.003
    N2330X-0.0631A-8.008
    N2340X-0.0569A-8.003
    N2350X-0.0508A-7.987
    N2360X-0.0448A-7.960
    N2370X-0.0391A-7.922
    N2380X-0.0336A-7.873
    N2390X-0.0284A-7.814
    N2400X-0.0235A-7.746
    N2410X-0.0190A-7.668
    N2420X-0.0147A-7.589
    N2430X-0.0109A-7.503
    N2440X-0.0077A-7.409
    N2450X-0.0050A-7.310
    N2460X-0.0029A-7.207
    N2470X-0.0013A-7.101
    N2480X-0.0004A-6.993
    N2490X-0.0001A-6.882
    N2500A-5.764
    N2510G00Z1.2362
    N2520G00X0.1249A-8.998
    N2530G01Z0.9750F19.7
    N2540G01X-0.1250F39.4
    N2550A-10.134
    N2560X-0.1248A-10.244
    N2570X-0.1239A-10.350
    N2580X-0.1224A-10.455
    N2590X-0.1203A-10.556
    N2600X-0.1177A-10.653
    N2610X-0.1146A-10.745
    N2620X-0.1109A-10.831
    N2630X-0.1067A-10.910
    N2640X-0.1023A-10.986
    N2650X-0.0975A-11.052
    N2660X-0.0923A-11.110
    N2670X-0.0868A-11.159
    N2680X-0.0812A-11.198
    N2690X-0.0753A-11.225
    N2700X-0.0692A-11.243
    N2710X-0.0631A-11.249
    N2720X-0.0569A-11.243
    N2730X-0.0508A-11.227
    N2740X-0.0448A-11.200
    N2750X-0.0391A-11.162
    N2760X-0.0336A-11.114
    N2770X-0.0284A-11.054
    N2780X-0.0235A-10.986
    N2790X-0.0190A-10.908
    N2800X-0.0147A-10.829
    N2810X-0.0109A-10.743
    N2820X-0.0077A-10.649
    N2830X-0.0050A-10.550
    N2840X-0.0029A-10.448
    N2850X-0.0013A-10.341
    N2860X-0.0004A-10.233
    N2870X-0.0001A-10.122
    N2880A-9.004
    N2890G00Z1.2362
    N2900G00X0.1249A-14.489
    N2910G01Z0.9750F19.7
    N2920G01A-12.239F39.4
    N2930X-0.1250
    N2940A-14.489
    N2950G00Z1.2362
    N2960G00X-0.0125A-12.240
    N2970G01Z0.9750F19.7
    N2980G01A-13.733F39.4
    N2990G00Z1.2362
    N3000G00X0.1249A-15.479
    N3010G01Z0.9750F19.7
    N3020G01X-0.1250F39.4
    N3030A-16.615
    N3040X-0.1248A-16.724
    N3050X-0.1239A-16.831
    N3060X-0.1224A-16.935
    N3070X-0.1203A-17.036
    N3080X-0.1177A-17.133
    N3090X-0.1146A-17.225
    N3100X-0.1109A-17.311
    N3110X-0.1067A-17.390
    N3120X-0.1023A-17.466
    N3130X-0.0975A-17.533
    N3140X-0.0923A-17.590
    N3150X-0.0868A-17.639
    N3160X-0.0812A-17.678
    N3170X-0.0753A-17.705
    N3180X-0.0692A-17.723
    N3190X-0.0631A-17.729
    N3200X-0.0569A-17.723
    N3210X-0.0508A-17.707
    N3220X-0.0448A-17.680
    N3230X-0.0391A-17.642
    N3240X-0.0336A-17.594
    N3250X-0.0284A-17.534
    N3260X-0.0235A-17.466
    N3270X-0.0190A-17.389
    N3280X-0.0147A-17.309
    N3290X-0.0109A-17.223
    N3300X-0.0077A-17.129
    N3310X-0.0050A-17.030
    N3320X-0.0029A-16.928
    N3330X-0.0013A-16.822
    N3340X-0.0004A-16.714
    N3350X-0.0001A-16.602
    N3360A-15.484
    N3370G00Z1.2362
    N3380G00X0.0000A-16.750
    N3390G01Z0.9750F19.7
    N3400G01X0.1249A-17.729F39.4
    N3410G00Z1.2362
    N3420G00X0.1208A-18.794
    N3430G01Z0.9750F19.7
    N3440G01X0.1162F39.4
    N3450A-18.877
    N3460X0.1208
    N3470A-18.794
    N3480X0.1249A-18.719
    N3490X0.1125
    N3500A-18.944
    N3510X0.1249
    N3520A-18.719
    N3530G00Z1.2362
    N3540G00X0.0624A-22.186
    N3550G01Z0.9750F19.7
    N3560G01X0.0700A-22.178F39.4
    N3570X0.0771A-22.160
    N3580X0.0836A-22.130
    N3590X0.0897A-22.088
    N3600X0.0953A-22.038
    N3610X0.1004A-21.977
    N3620X0.1051A-21.908
    N3630X0.1092A-21.833
    N3640X0.1160A-21.664
    N3650X0.1209A-21.473
    N3660X0.1238A-21.269
    N3670X0.1248A-21.061
    N3680X0.1238A-20.850
    N3690X0.1209A-20.647
    N3700X0.1160A-20.456
    N3710X0.1129A-20.368
    N3720X0.1092A-20.287
    N3730X0.1051A-20.211
    N3740X0.1004A-20.143
    N3750X0.0953A-20.081
    N3760X0.0897A-20.031
    N3770X0.0836A-19.990
    N3780X0.0771A-19.959
    N3790X0.0700A-19.941
    N3800X0.0624A-19.934
    N3810X-0.0626
    N3820X-0.0701A-19.941
    N3830X-0.0772A-19.959
    N3840X-0.0837A-19.990
    N3850X-0.0898A-20.031
    N3860X-0.0954A-20.081
    N3870X-0.1005A-20.143
    N3880X-0.1052A-20.211
    N3890X-0.1093A-20.287
    N3900X-0.1161A-20.456
    N3910X-0.1210A-20.647
    N3920X-0.1239A-20.850
    N3930X-0.1249A-21.061
    N3940X-0.1239A-21.269
    N3950X-0.1210A-21.473
    N3960X-0.1161A-21.664
    N3970X-0.1130A-21.752
    N3980X-0.1093A-21.833
    N3990X-0.1052A-21.908
    N4000X-0.1005A-21.977
    N4010X-0.0954A-22.038
    N4020X-0.0898A-22.088
    N4030X-0.0837A-22.130
    N4040X-0.0772A-22.160
    N4050X-0.0701A-22.178
    N4060X-0.0626A-22.186
    N4070G00Z1.2362
    N4080G00A-23.176
    N4090G01Z0.9750F19.7
    N4100G01X-0.0701A-23.181F39.4
    N4110X-0.0772A-23.201
    N4120X-0.0837A-23.232
    N4130X-0.0898A-23.271
    N4140X-0.0954A-23.323
    N4150X-0.1005A-23.383
    N4160X-0.1052A-23.451
    N4170X-0.1093A-23.527
    N4180X-0.1161A-23.698
    N4190X-0.1210A-23.887
    N4200X-0.1239A-24.090
    N4210X-0.1249A-24.301
    N4220X-0.1239A-24.510
    N4230X-0.1210A-24.713
    N4240X-0.1161A-24.904
    N4250X-0.1130A-24.992
    N4260X-0.1093A-25.073
    N4270X-0.1052A-25.149
    N4280X-0.1005A-25.217
    N4290X-0.0954A-25.278
    N4300X-0.0898A-25.329
    N4310X-0.0837A-25.370
    N4320X-0.0772A-25.401
    N4330X-0.0701A-25.419
    N4340X-0.0626A-25.426
    N4350X0.0624
    N4360X0.0700A-25.419
    N4370X0.0771A-25.401
    N4380X0.0836A-25.370
    N4390X0.0897A-25.329
    N4400X0.0953A-25.278
    N4410X0.1004A-25.217
    N4420X0.1051A-25.149
    N4430X0.1092A-25.073
    N4440X0.1160A-24.904
    N4450X0.1209A-24.713
    N4460X0.1238A-24.510
    N4470X0.1248A-24.301
    N4480X0.1238A-24.090
    N4490X0.1209A-23.887
    N4500X0.1160A-23.698
    N4510X0.1129A-23.610
    N4520X0.1092A-23.527
    N4530X0.1051A-23.451
    N4540X0.1004A-23.383
    N4550X0.0953A-23.323
    N4560X0.0897A-23.271
    N4570X0.0836A-23.232
    N4580X0.0771A-23.201
    N4590X0.0700A-23.181
    N4600X0.0624A-23.176
    N4610X-0.0626
    N4620G00Z1.2362
    N4630G00X0.1250A-26.416
    N4640G01Z0.9750F19.7
    N4650G01X-0.1250F39.4
    N4660X0.0626A-28.216
    N4670X-0.1250A-30.016
    N4680X0.1250
    N4690G00Z1.2362
    N4700G00X0.5000A-36.001
    N4710G01Z0.9750F19.7
    N4720G01X-0.5000F39.4
    N4730X-0.5001A-35.798
    N4740X-0.5005A-35.594
    N4750X-0.5012A-35.387
    N4760X-0.5021A-35.178
    N4770X-0.5033A-34.970
    N4780X-0.5048A-34.761
    N4790X-0.5066A-34.548
    N4800X-0.5086A-34.336
    N4810X-0.5110A-34.124
    N4820X-0.5137A-33.911
    N4830X-0.5166A-33.697
    N4840X-0.5199A-33.485
    N4850X-0.5235A-33.272
    N4860X-0.5275A-33.058
    N4870X-0.5317A-32.847
    N4880X-0.5363A-32.635
    N4890X-0.5412A-32.424
    N4900X-0.5464A-32.216
    N4910X-0.5519A-32.009
    N4920X-0.5577A-31.803
    N4930X-0.5639A-31.600
    N4940X-0.5703A-31.398
    N4950X-0.5771A-31.199
    N4960X-0.5842A-31.002
    N4970X-0.5916A-30.810
    N4980X-0.5993A-30.619
    N4990X-0.6072A-30.432
    N5000X-0.6155A-30.248
    N5010X-0.6240A-30.068
    N5020X-0.6328A-29.894
    N5030X-0.6418A-29.721
    N5040X-0.6511A-29.553
    N5050X-0.6607A-29.391
    N5060X-0.6704A-29.233
    N5070X-0.6804A-29.080
    N5080X-0.6906A-28.930
    N5090X-0.7010A-28.788
    N5100X-0.7116A-28.650
    N5110X-0.7223A-28.516
    N5120X-0.7332A-28.389
    N5130X-0.7443A-28.266
    N5140X-0.7555A-28.151
    N5150X-0.7668A-28.039
    N5160X-0.7782A-27.935
    N5170X-0.7897A-27.836
    N5180X-0.8013A-27.742
    N5190X-0.8130A-27.654
    N5200X-0.8248A-27.571
    N5210X-0.8365A-27.496
    N5220X-0.8484A-27.424
    N5230X-0.8602A-27.359
    N5240X-0.8720A-27.300
    N5250X-0.8839A-27.247
    N5260X-0.8957A-27.199
    N5270X-0.9075A-27.156
    N5280X-0.9193A-27.120
    N5290X-0.9311A-27.087
    N5300X-0.9427A-27.060
    N5310X-0.9543A-27.039
    N5320X-0.9659A-27.022
    N5330X-0.9774A-27.010
    N5340X-0.9887A-27.003
    N5350X-1.0000A-27.001
    N5360A27.001
    N5370X-0.9887A27.003
    N5380X-0.9774A27.010
    N5390X-0.9659A27.022
    N5400X-0.9543A27.039
    N5410X-0.9427A27.060
    N5420X-0.9311A27.087
    N5430X-0.9193A27.120
    N5440X-0.9075A27.156
    N5450X-0.8957A27.199
    N5460X-0.8839A27.247
    N5470X-0.8720A27.300
    N5480X-0.8602A27.359
    N5490X-0.8484A27.424
    N5500X-0.8365A27.496
    N5510X-0.8248A27.571
    N5520X-0.8130A27.654
    N5530X-0.8013A27.742
    N5540X-0.7897A27.836
    N5550X-0.7782A27.935
    N5560X-0.7668A28.039
    N5570X-0.7555A28.151
    N5580X-0.7443A28.266
    N5590X-0.7332A28.389
    N5600X-0.7223A28.516
    N5610X-0.7116A28.650
    N5620X-0.7010A28.788
    N5630X-0.6906A28.930
    N5640X-0.6804A29.080
    N5650X-0.6704A29.233
    N5660X-0.6607A29.391
    N5670X-0.6511A29.553
    N5680X-0.6418A29.721
    N5690X-0.6328A29.894
    N5700X-0.6240A30.068
    N5710X-0.6155A30.248
    N5720X-0.6072A30.432
    N5730X-0.5993A30.619
    N5740X-0.5916A30.810
    N5750X-0.5842A31.002
    N5760X-0.5771A31.199
    N5770X-0.5703A31.398
    N5780X-0.5639A31.600
    N5790X-0.5577A31.803
    N5800X-0.5519A32.009
    N5810X-0.5464A32.216
    N5820X-0.5412A32.424
    N5830X-0.5363A32.635
    N5840X-0.5317A32.847
    N5850X-0.5275A33.058
    N5860X-0.5235A33.272
    N5870X-0.5199A33.485
    N5880X-0.5166A33.697
    N5890X-0.5137A33.911
    N5900X-0.5110A34.124
    N5910X-0.5086A34.336
    N5920X-0.5066A34.548
    N5930X-0.5048A34.761
    N5940X-0.5033A34.970
    N5950X-0.5021A35.178
    N5960X-0.5012A35.387
    N5970X-0.5005A35.594
    N5980X-0.5001A35.798
    N5990X-0.5000A36.001
    N6000X0.5000
    N6010X0.5001A35.798
    N6020X0.5005A35.594
    N6030X0.5012A35.387
    N6040X0.5021A35.178
    N6050X0.5033A34.970
    N6060X0.5048A34.761
    N6070X0.5066A34.548
    N6080X0.5086A34.336
    N6090X0.5110A34.124
    N6100X0.5137A33.911
    N6110X0.5166A33.697
    N6120X0.5199A33.485
    N6130X0.5235A33.272
    N6140X0.5275A33.058
    N6150X0.5317A32.847
    N6160X0.5363A32.635
    N6170X0.5412A32.424
    N6180X0.5464A32.216
    N6190X0.5519A32.009
    N6200X0.5577A31.803
    N6210X0.5639A31.600
    N6220X0.5703A31.398
    N6230X0.5771A31.199
    N6240X0.5842A31.002
    N6250X0.5916A30.810
    N6260X0.5993A30.619
    N6270X0.6072A30.432
    N6280X0.6155A30.248
    N6290X0.6240A30.068
    N6300X0.6328A29.894
    N6310X0.6418A29.721
    N6320X0.6511A29.553
    N6330X0.6607A29.391
    N6340X0.6704A29.233
    N6350X0.6804A29.080
    N6360X0.6906A28.930
    N6370X0.7010A28.788
    N6380X0.7116A28.650
    N6390X0.7223A28.516
    N6400X0.7332A28.389
    N6410X0.7443A28.266
    N6420X0.7555A28.151
    N6430X0.7668A28.039
    N6440X0.7782A27.935
    N6450X0.7897A27.836
    N6460X0.8013A27.742
    N6470X0.8130A27.654
    N6480X0.8248A27.571
    N6490X0.8365A27.496
    N6500X0.8484A27.424
    N6510X0.8602A27.359
    N6520X0.8720A27.300
    N6530X0.8839A27.247
    N6540X0.8957A27.199
    N6550X0.9075A27.156
    N6560X0.9193A27.120
    N6570X0.9311A27.087
    N6580X0.9427A27.060
    N6590X0.9543A27.039
    N6600X0.9659A27.022
    N6610X0.9774A27.010
    N6620X0.9887A27.003
    N6630X1.0000A27.001
    N6640A-27.001
    N6650X0.9887A-27.003
    N6660X0.9774A-27.010
    N6670X0.9659A-27.022
    N6680X0.9543A-27.039
    N6690X0.9427A-27.060
    N6700X0.9311A-27.087
    N6710X0.9193A-27.120
    N6720X0.9075A-27.156
    N6730X0.8957A-27.199
    N6740X0.8839A-27.247
    N6750X0.8720A-27.300
    N6760X0.8602A-27.359
    N6770X0.8484A-27.424
    N6780X0.8365A-27.496
    N6790X0.8248A-27.571
    N6800X0.8130A-27.654
    N6810X0.8013A-27.742
    N6820X0.7897A-27.836
    N6830X0.7782A-27.935
    N6840X0.7668A-28.039
    N6850X0.7555A-28.151
    N6860X0.7443A-28.266
    N6870X0.7332A-28.389
    N6880X0.7223A-28.516
    N6890X0.7116A-28.650
    N6900X0.7010A-28.788
    N6910X0.6906A-28.930
    N6920X0.6804A-29.080
    N6930X0.6704A-29.233
    N6940X0.6607A-29.391
    N6950X0.6511A-29.553
    N6960X0.6418A-29.721
    N6970X0.6328A-29.894
    N6980X0.6240A-30.068
    N6990X0.6155A-30.248
    N7000X0.6072A-30.432
    N7010X0.5993A-30.619
    N7020X0.5916A-30.810
    N7030X0.5842A-31.002
    N7040X0.5771A-31.199
    N7050X0.5703A-31.398
    N7060X0.5639A-31.600
    N7070X0.5577A-31.803
    N7080X0.5519A-32.009
    N7090X0.5464A-32.216
    N7100X0.5412A-32.424
    N7110X0.5363A-32.635
    N7120X0.5317A-32.847
    N7130X0.5275A-33.058
    N7140X0.5235A-33.272
    N7150X0.5199A-33.485
    N7160X0.5166A-33.697
    N7170X0.5137A-33.911
    N7180X0.5110A-34.124
    N7190X0.5086A-34.336
    N7200X0.5066A-34.548
    N7210X0.5048A-34.761
    N7220X0.5033A-34.970
    N7230X0.5021A-35.178
    N7240X0.5012A-35.387
    N7250X0.5005A-35.594
    N7260X0.5001A-35.798
    N7270X0.5000A-36.001
    N7280G00Z1.2362
    N7290G00Z1.2362
    N7300G00X0.0000A0.000
    N7310M09
    N7320M30
    Oct 2004
    188
    go into the configure menu and look under viewports and set the xyza view port an it should work. i just tried it on 2.1.4 and 3 versions i dont have 2.3 but it should have the same settings. the flashcut guys always seem to find time to help.
    Jun 2003
    15
    Hey Rob. Thanks for taking the time to help.I apreciate it. I took your advise and emailed Flashcut. Ron Worth replyed back the same day. My old version (2.0.3) will not do what I am trying to do. I downloaded Version 3 demo and it worked fine. Looks like I need to get my wallet out and upgrade.
    Thanks again
    Oct 2004
    188
    do you have to get a new signal generator. or can they upgrade you with a chip and software. if you wine a little they will knock a few bucks off the upgrade price.
    Jun 2003
    15
    Ron said he will give me 500.00 trade in for my old signal generator. I would like to upgrade but from the specs for the new controller my existing computer is a little lacking and I just am not in a position right now to make that much of a investment.
    I have been trying to get Mach3 and my Flashcut driver to play nice but so far no go.
    If anybody reading this has any experience doing this I would appreciate any help.
    Jul 2011
    Hi Everyone.
    I have been reading these posts with great interest.
    I also have a flashcut four axis controller and i run version 2.04
    I set it up on a benchtop milling machine.
    I have never used the fourth axis though I have had the machine quite a few years ago. health problems put everything on hold for a while.
    Now I am just starting to get back into everything and could do with some advice please.
    I have got to the stage of adding a stepper motor onto the back of a small woodlathe ( carbatec ) and am hoping to run it as the fourth axis on the bed of the milling machine.
    I work only with wood and hope to produce spiral turnings ( barley twist and fluting ) also to decorate and embellish small turnings if possible ( similar to stuff done on those horribly expensive rose engines and holtzappfell lathes of the Victorian time )
    I have tried the program cnc wrapper have suffered the same sort of problems as mentioned by densman when testing the files that come with the program, the display is shown as flat rather than cylindrical and the machine doesnt seem to like the code.
    I was also wondering if it would be possible to make the flashcut controller like mach3 as I have read lots of posts saying how good that software is.
    Any help or advice that anyone can give me will be very much appreciated.
    Best regards.
    graham
    Mar 2004
    413
    "Make the Flashcut controller like Mach".....
    Ah, not sure why you would want to do that... But frankly, version 2.04 is from early 2006 as best I can tell. So many new features and code support additions have been added since then, it would almost be a must to upgrade for anything beyond basic 2.5d or 3d work.
    I realize this is a Flashcut forum, but really, if people want to try Mach, it doesn't take much to make an alternative cable to connect to your driver cabinet and give it a whirl. I can tell you that you will find a few things missing that you have come to really appreciate, even though mach has "workarounds". You may never get that far though. By the time your somewhat happy with the operation from fiddling with the plethora of machs vaguely defined configuration checkboxes and dialogs, your first runs will wonder why you left the really well laid out controller Flashcut already is. Granted, 2.04 is going to be a bit antiquated though in 2012.
    Chris L
    Mar 2004
    413
    Quote Originally Posted by densman View Post
    For anyone reading this old message, I have installed Flashcuts latest version 4 (USB) on an old 1.2G processor, 256m ram Laptop and it is running very well.
    Chris L
    Jul 2011
    Hi Chris.
    Thanks very much for your reply.
    Sorry, I meant to ask if it was possible to get the flashcut four axis driver box ( not controller ) to work with mach so I could try it out.
    You mention that it is possible to make an alternative cable to connect to your driver cabinet and run mach3, would you mind giving me some advice or information on how to go about it please as I am new to elecronics.
    Thanks .
    Best regards.
    Graham
    Mar 2004
    413
    Quote Originally Posted by grahamsimpkin View Post
    Hi Chris.
    Thanks .
    Best regards.
    Graham
    Graham,
    If you wanted to try Mach on your currently Flashcut driven machine, it does come down to a simple cable, breakout board or configurable pin db25 adapter.
    Essentially, your Flashcut signal generator has a db25 pin connector on the back. Out of this plug (among other things on newer versions), are the signals that tell the motor drivers what to do. The most basic explanation of the magic behind a system like this, is simple. There are pulses that go out of the STEP pins to tell the motors how far and how fast to turn, and there is a plus or minus signal that leaves the DIR pins to tell the motors which direction it should be turning. Each axis has a STEP, DIR and a common ground.
    Mach has the same scenario and even uses the same style plug. They just use different pins on that plug.
    For example, FC uses pin 9 for axis 1 DIR, and pin 13 for axis 1 STEP. Mach uses a different set of pins, so you have to sit down with a piece of paper and draw a map of what pins going into your driver box need what pins coming out of your parallel port directly on the PC. You do not use the Flashcut box or software at all with new cable or adapter in place. And, you could make it all run with the demo of Mach,,, it will cut 500 lines of code for free they tell me.
    If you do it right, you could actually swap back and forth between the two programs just by swapping cables.
    If you were to do this, I would hope you would come back and tell us your experiences. If you dont have a more recent version of FC, Mach might impress you with features that are newer than your FC version has. I have swapped two Mach installations to Flashcut. You can not find a more ergonomic, easy to train users, robust control to date. I couldn't imagine not using FC unless I was really down and out and could not afford it.
    Chris L
    Jul 2011
    Quote Originally Posted by datac View Post
    Graham,
    Hi Chris.
    Thanks very much for your help and advice.
    I will have a go at making the cable, try it out, and will definately be back here to let everyone know how I get on.
    Best regards.
    graham
  1. the Difference of 2-Axis and 3-Axis of Vertical Mill Machine
    By begacon in forum Knee Vertical Mills
    Last Post: 07-30-2009, 12:31 PM
  2. Compare Catia and MCX2 for multi axis lathe/4 axis mill
    By bob1112 in forum Uncategorised CAM Discussion
    Last Post: 10-11-2008, 01:15 AM
  3. How can I coupling a stepper motor axis directly to other axis?
    By meknik2001 in forum Stepper Motors / Drives
    Last Post: 05-08-2008, 07:54 PM
  4. One axis (z-axis?) computer controlled testing device
    By TsThorsell in forum Stepper Motors / Drives
    Last Post: 02-07-2008, 07:38 PM
  5. New Design - Hybrid 3-Axis Router/4-axis Foam Hot Wire Cutter
    By the__extreme in forum CNC Wood Router Project Log
    Last Post: 02-26-2007, 09:58 PM
