587,215 active members*
3,051 visitors online*
Results 1 to 8 of 8
    Dec 2011
    Grounding for DC-KIII?
    Hi all,
    I've just ordered a DC-KIII off of eBay. I'm very excited for making my first cuts.
    There's something in the instructions (located here: http://www.jinlantrade.com/Stock%20files/K40Manual.pdf ) that doesn't make sense to me. On the first page, at a seemingly random location, it warns "The switch must connect to secure ground wire!"
    Does anyone know what this is about?
    Thanks,
    Ben
    Dec 2003
    24223
    The terseness of the sentence and lack of reference makes it virtually useless?
    I see they are a just a general Chinese trading Co with offices in NY, there does not appear to be a link to ask for support?
    Al.
    Albert E.
    Dec 2011
    I think that website might belong to the manufacturer, though I'm not sure. It seems like a lot of the sellers of this particular laser link to that instruction manual.
    This is the laser I bought in particular: http://www.ebay.ca/itm/180827790568?...t_14327wt_1141
    Dec 2003
    24223
    Quote Originally Posted by B3nzilla View Post
    Try the ebay seller?
    Al.
    Albert E.
    Dec 2011
    Jaha! Just got my laser today!
    I think that instruction might be obsolete.
    There is a terminal post at the back that says "Ground wire joint", but on the inside of the machine, it appears to be connected to the ground of the (north American) plug.
    Dec 2011
    It all makes sense now. They provide a standard power cord with the machine with a Chinese plug and they also ship a Chinese to North American adaptor. The adaptor's ground plug is not connected.
    If using their adaptor, one definitely needs to ground the machine separately. The alternative is to just use a standard North American power plug. Like the one's that go into the backs of monitors and laptop power bricks.
    May 2012
    Hi All,
    I'm new to laser cutting, and looking to cut ~50 um plastic sheets. I need to cut holes that are 170 um in diameter. I just found the DC-KIII on e-bay and I'm wondering if you think it would work. How do you like yours?
    Thanks.
    Oct 2007
    385
    Excuse my ignorance, but what is 50um or 170um as far as size goes. I have this laser and i routinely cut 3mm material and on sometimes 6mm. Mostly acrylic or wood.
    Milt
  1. 40 watt DC-KIII laser finally arrived !
    By SScnc in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 11-30-2011, 03:23 AM
  2. Componet Grounding
    By Mr.Chips in forum CNC Machine Related Electronics
    Last Post: 12-29-2009, 07:55 PM
  3. Grounding question
    By dmparrott in forum CNC Machine Related Electronics
    Last Post: 08-23-2007, 02:50 PM
  4. grounding Q's
    By anthony in forum CNC Machine Related Electronics
    Last Post: 05-14-2005, 11:24 PM
