587,313 active members*
3,366 visitors online*
IndustryArena Forum > WoodWorking Machines > DIY CNC Router Table Machines > New CNC router build -- thoughts, comments, questions...
Results 1 to 8 of 8
    Feb 2009
    4
    Hey all, i've been looking through the forum for a couple months now and decided to start a design of my own... i've never built anything like this before but being a cabinetmaker im confident in the build of the structure... i just have some questions about center of gravities of my components and hardware.
    here are the specs
    i want a cutting area of 26" x 74" (2' x 6' plus 2" on each axis to ensure a comfortable 2' x 6' cutting area)
    i had initially wanted a 6" z axis but i think my design employs about a 5.25" z axis travel, which is fine with me.
    im just going to be cutting mdf and wood with the machine but i would like to be able to cut aluminum without a problem.
    im designing the machine to be built out of mdf with skate bearing/aluminum angle linear motion.
    questions
    im trying to design the machine such that when it milling there is minimal stress on the bearings. i assume you'd want to place the center of gravity of the entire gantry centered on the x-axis bearings??
    i basically have a long and narrow cutting table (2' x 6'). i want to minimize the x-axis deflection as the gantry moves along the length of the table. ive been toying with the idea of utilizing a cabling system to correct the deflection. the cables arent drawn in my design but i would tie the front and back legs of the table together on each side... then tie each leg of the table to the overhanging table supports that run through the table ends. good idea? or too overkill?
    attached are some pics of my design and the cabling system... any advice would be greatly appreciated.
    also, ill attach a list of the parts ive semi-decided on
    http://www.probotix.com/index.php?vi...&product_id=52
    my gantry is looking like it will weigh about 50-70lbs and my router/router carriage will weigh about 10-12lbs will these motors suffice?
    im thinking 3/8" 10tpi acme lead screws on all axis w/ with standard anti backlash nuts... i read some specs on the 3/8" lead screws and it looks like it'll handle the load just fine... is there a reason to upgrade to 1/2"?
    thanks for the help!
    -tim
    Attached Thumbnails Attached Thumbnails cnc complete.JPG   gantry.JPG   cabling system.JPG
    35538
    One reason to use 1/2" screws is to minimize whipping of the screw at higher rpm's. 1/2" is much stiffer, but even 1/2" screws will whip. 10 tpi screws are not the best choice, as they will limit your speed. Most builders are using 1/2-10 or 1/2-8 2 start or even 1/2-10 5 start screws (5, 4 and 2 turns per inch). These will let the screws spin slower, which will minimize whipping, and also give you higher speeds.
    Feb 2009
    4
    does the cad/cam software or stepper driver boards allow you to run a 1/2" with one motor and 3/8" with the y and z axis? or should i not even bother and go all 1/2"?
    35538
    It's the machine control software you need to worry about, and yes, most should let you mix and match. But just about every machine you'll see here uses 1/2", so I'd say stick to the 1/2" on all axis.
    Feb 2009
    4
    ok great, thanks gerry... ill check that off the list and just stick to 1/2"... what do you think of the motor choice for driving a fairly heavy setup but still wanting decent rapid speeds?
    35538
    You probably should go with drives that can handle more than 24V, or you'll be disappointed with the performance. The Gecko G540 is quickly becoming the drive of choice among home builders.
    And don't skimp on the Z motor, it should be the same torque as the others.
    Feb 2009
    4
    the gecko540 seems kind of expensive but ive read great things about it... im mostly only interested in 3 axis now... if i purchase the g540 can i disable the 4th axis? or do i just not hook up a motor to it? thanks
    Jan 2006
    106
    You dont have to even purchase the 4th motor if your not going to use it, Good luck!
  1. Replies: 299
    Last Post: 10-16-2022, 01:54 PM
  2. Will Build a Moving Gantry ROUTER-comments appreciated.
    By CNCfun&games in forum CNC Wood Router Project Log
    Last Post: 12-25-2016, 01:06 AM
  3. Router build questions. OPINIONS WANTED!
    By initialimage in forum DIY CNC Router Table Machines
    Last Post: 12-03-2008, 12:25 PM
  4. comments and I have a couple of questions
    By setguy in forum Commercial CNC Wood Routers
    Last Post: 10-05-2008, 01:51 AM
  5. New Build! need some thoughts!
    By papagolf in forum DIY CNC Router Table Machines
    Last Post: 06-21-2008, 05:35 AM
