587,216 active members*
2,447 visitors online*
Results 1 to 3 of 3
    Jun 2006
    59
    Tapping 4-40 on CNC
    I have posted regarding this subject before, but I would like to know what tool holder shops are using to form tap 4-40 in 6061. I have done quite a bit of research, but can't pinpoint which holder would be the best for this application. Or should I run solid with a collet? My machine is older, but does have the tapping autocycle.
    Any help is greatly appreciated.
    Thank you
    Star SR20RII/Fanuc 18i, DMG CTX310V4/Fanuc 32i, DMG CTX310ECO/Siemens 8400, Mori NV5000/MAPS, Bridgeport 760/Fanuc 18i, Kiamaster 4NEII60/Fanuc 3t;Partmaker, Gibbscam
    Nov 2007
    479
    I use a rigid tap holder with quick change tap adapters for each size of tap. Any collet should work as well though.
    Jul 2007
    60
    Depending on how used your m/c is and whether it supports rigid tapping i would go for a 'floating' holder - one that lets the tap either pull out or compress - you will have more control over getting the tap to cut without snapping.
    PCM do a nice version that fits directly into an ER25 collet holder.
    ST
  1. Replies: 24
    Last Post: 05-01-2014, 07:02 AM
  2. Tapping on a TL-2
    By rbest27 in forum Haas Mills
    Last Post: 12-02-2007, 12:47 AM
  3. Rigid tapping or tapping head
    By kentavv in forum Charter Oak Automation Support Forum
    Last Post: 09-24-2006, 06:08 PM
  4. Tapping 303 S.s.
    By drill in forum MetalWork Discussion
    Last Post: 02-04-2006, 03:23 AM
  5. tapping head vs hand/cordless tapping machine....
    By InspirationTool in forum Uncategorised MetalWorking Machines
    Last Post: 09-13-2005, 02:10 AM
