Get a three phase motor and VFD, if you dont have a low gear, you may run in to a problem with very low speed unless you get a higher quality flux-vector VFD or one with encoder speed control.
Also a cooling fan would need to be fitted for low speed operation.
The belt drive should also preferabally be timing belt.
If you buy a new motor, get a vector drive rated one.
Al.
Albert E.
