I crashed my probe the other day. I left a variable set for a part that was programmed for .750 exposed, yet i had a 1.375 part in there. Poor planning.... i usually rapid to ~1.5 above part, then m01 and eye up distance to go. g54 Part zero is usually top of part, this time g54 was programmed as g54fixture face z+ part length and then assigning z face offset to g129.
Should I insert the G31 code where i put !!!!!!!!!!!!!!!!!!!!!!!!!?
is there a code to take it out of this mode? Cleared at mo6?
Also since i am using one sub for tool postion and one for actual motion cmds, with an m01 to check variables. Should i restate g31 in the O00901 (PROBE PART) program, that moves the probe from rapid position to part for probing?
I use a generic tool approach subprogram to move within z1.5 of part face then my controlled f10. ipm moves are setup like this :
O00903 (TOOL CHANGE SUB )
M09
G91 G28 Z0 M05
G90 G#8 G00 X#24 Y#25
T#20 M06
IF [ #20 EQ 1.0 ] GOTO2
S#19 M03
M08
N2 (PROBE SKIP SXXX M03, M08 CMD)
!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!!!!!! G31??
G43 H#11 G00 Z#26
G01 F20. Z#23
G01 F20. Z - #21
(TOOL APPROACH DONE >> MOTION)
M99
O00901 (PROBE PART)
N901 (ACTUAL PROBING COMMANDS)
(PROBE TOP OF PART FOR Z OFFESET)
G90 G#8
!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!! G31???
G01 Y - #619 Z#616 F30.
G65 P9023 A9. S129
G00 X0 Y0
(PROBE X Y WEB)
G65 P9023 A4. Y#600 Z-0.318 S129
G65 P9023 A4. X#600 Z-0.318 S129
G00 Z1.5
N90199 (PROBING DONE >> RTM)
G91 G28 Z0
G90 M99
Just needed verification that g31 will stop the machine hits something with the probe.
G31 on haas vf-2 = feed untill skip fucntion.
Saw this on another post.....
"I don't understand that if you have the Renishaw 9000 macro's it should include a protected move routine, i.e. you should never move any axis with the probe in place without a G31 in the routine, which the protected move has.
If a rapid move to initial position is performed and a probe collision occurs, all axis will stop.
If Fadal have modified the probe routines, to my mind they should supply comprehensive documentation on usage.
Whats with the uncontrollable Rapids?
A Renishaw crash can be Very expensive.!"
Not relevant but if anyone can use it to learn parametric.
Here is the MATH SUB that is assigning vars based on the family of parts :
G103 P0
N90710 (----SET PROBING VARIABLES-----)
(#605= PART # FLAGIAMATERS - user spec in main)
(#606= PART # FLAG: LENGTHS - user spec in main)
(#617= PRINT D + .118)
IF [ [ #605 EQ 2.5 ] OR [ #605 EQ 3.5 ] ] THEN #617= 0.391
IF [ #605 EQ 4.5 ] THEN #617= 0.578
IF [ [ #605 EQ 5.5 ] OR [ #605 EQ 6.0 ] ] THEN #617= 0.899
(#619= EXIST. HOLE R + STYLUS R)
#619= #617 / 2 + 0.118
(#616= +Z APPROACH FOR PROBING)
IF [ [ #606 EQ 1.0 ] AND [ #605 EQ 2.5 ] ] THEN #616= .750
IF [ [ #606 EQ 2.0 ] AND [ #605 EQ 2.5 ] ] THEN #616= 1.35
N90720 (----SET MACHINING VARS-----)
N90721 (GENERAL MACH VARS)
(#623= Z DEPTH FOR GROOVE)
IF [ [ #605 GE 2.4 ] AND [ #605 LE 4.6 ] ] THEN #623= 0.05
IF [ [ #605 GE 5.4 ] AND [ #605 LE 6.1 ] ] THEN #623= 0.073
N90722 (12:00 SLOT VARS)
(#624= 12:00 RPD POS, HYP)
(#624= #617 / 2 - 0.100
IF [ #605 EQ 2.5 ] THEN #624= .0955
IF [ #605 EQ 3.5 ] THEN #624= 1.0
IF [ #605 EQ 4.5 ] THEN #624= 2.0
IF [ #605 EQ 5.5 ] THEN #624= 3.0
IF [ #605 EQ 6.0 ] THEN #624= 4.0
(#625= 12:00 Y END PT)
IF [ #605 EQ 2.5 ] THEN #625= 0.2344
IF [ #605 EQ 3.5 ] THEN #625= 1.0
IF [ #605 EQ 4.5 ] THEN #625= 2.0
IF [ #605 EQ 5.5 ] THEN #625= 3.0
IF [ #605 EQ 6.0 ] THEN #625= 4.01
N90723 (----4:00, 8:00 RPD VARS-----)
(#626= 4:00, 8:00 SLOTS RPD X POS)
IF [ #605 EQ 2.5 ] THEN #626= .0851
IF [ #605 EQ 3.5 ] THEN #626= 1.0
IF [ #605 EQ 4.5 ] THEN #626= 2.0
IF [ #605 EQ 5.5 ] THEN #626= 3.0
IF [ #605 EQ 6.0 ] THEN #626= 4.0
(#627= 4:00, 8:00 SLOTS RPD Y POS)
IF [ #605 EQ 2.5 ] THEN #627= .0434
IF [ #605 EQ 3.5 ] THEN #627= 1.0
IF [ #605 EQ 4.5 ] THEN #627= 2.0
IF [ #605 EQ 5.5 ] THEN #627= 3.0
IF [ #605 EQ 6.0 ] THEN #627= 4.0
N90724 (----4:00, 8:00 MACH. VARS-----)
(#628= 4:00, 8:00 SLOTS MACH X POS)
IF [ #605 EQ 2.5 ] THEN #628= .2088
IF [ #605 EQ 3.5 ] THEN #628= 1.0
IF [ #605 EQ 4.5 ] THEN #628= 2.0
IF [ #605 EQ 5.5 ] THEN #628= 3.0
IF [ #605 EQ 6.0 ] THEN #628= 4.0
(#629= 4:00, 8:00 SLOTS MACH Y POS)
IF [ #605 EQ 2.5 ] THEN #629= .1064
IF [ #605 EQ 3.5 ] THEN #629= 1.0
IF [ #605 EQ 4.5 ] THEN #629= 2.0
IF [ #605 EQ 5.5 ] THEN #629= 3.0
IF [ #605 EQ 6.0 ] THEN #629= 4.0
N90799 (MATH DONE >> RTM)
G103 P1
M99
