587,216 active members*
3,167 visitors online*
Thread: Small Box
Results 1 to 5 of 5
    Mar 2016
    33
    Small Box
    I have been able to make this box with a 1/4" Flat End Mill and a 1/8 round over.
    I can use a jig to hold 3 boxes at once to mill out the pocket.
    Now i'n milling out the lids for the box
    Next I cut the lids using a miter saw .
    The problem I'm having is how do I hold down this lid to mill off the bottom part. I can make a jig that holds one but trying to hold more than that is impossible using friction.
    Any way to make a small vacuum hold down for under $100 or something that will work?
    Jan 2016
    11
    Re: Small Box
    Quote Originally Posted by CosmicGlenn View Post
    ...snip...
    ...snip...
    ...snip...
    Hello CosmicGlenn,
    This is from a newbie still in the process of building my CNC router, so take this suggestion with a grain of salt.
    I would suggest reversing your order of operations. First, mill off the top part like normal but mill holes for two registration pins on a line through the center of your board/boxes. Next, flip your board over and align the holes with two pins in your spoilboard. Mill the bottom of the boxes. You can either mill them out leaving some tabs that you cut out with your miter saw and sand off the stubs or do the full cut with the miter saw.
    For better directions on double sided milling, check Shopbot's YouTube channel for a video that walks through the process.
    Jonathan
    Sent from my SM-P900 using Tapatalk
    Mar 2016
    33
    Re: Small Box
    Hi Jonathlee
    I found that pin idea very useful.I made a jig that holds 4 lids and pins hold the Jig. The only problem I got is there are no limit switches on my machine. So if it gets out of place then I have trouble lining the bit to exactly where it was.
    Jan 2016
    11
    Re: Small Box
    Hello CosmicGlenn,
    Here's how to re-register a jig.
    https://youtu.be/GJ0m6OKHiQc
    If you want to make a parallel rule like Peter shows using, here is his instruction video for that:
    https://youtu.be/DgHdgIt7erU
    I highly recommend his Youtube channel, CncNutz.
    Jonathan
    Sent from my HTC6525LVW using Tapatalk
    Mar 2016
    33
    Re: Small Box
    I like that but my cnc is soo small i dont think i can make it work
  1. Replies: 0
    Last Post: 12-25-2015, 12:12 AM
  2. Belt/Pulley size? How small is too small?
    By Wallybanger in forum Uncategorised MetalWorking Machines
    Last Post: 09-11-2014, 09:57 PM
  3. Questions -- Small CNC Router with VERY SMALL Work Area, Ideas?
    By Building in forum DIY CNC Router Table Machines
    Last Post: 02-03-2012, 11:36 PM
  4. Measuring small angles on small workpieces.
    By skiingman in forum Calibration / Measurement
    Last Post: 04-02-2009, 01:40 AM
