587,655 active members*
3,789 visitors online*
IndustryArena Forum > CNC Electronics > Servo Motors / Drives > Speed control (not a servo amp) for BLDC motors?
Results 1 to 2 of 2
    May 2005
    674
    I'm thinking about using a Parker brand frameless kit motor to power a mill spindle. I'm particularly drawn to the direct drive ability and low profile. They are BLDC motors.
    Is there a way to power and control these motors without a servo amp, but rather a simple and less expensive speed control? I'm not yet familiar with BLDC motors.
    These are the motors.
    http://www.parker.com/ead/cm2.asp?cmid=10547
    Some of them are supplied with an integrated commutation assembly.
    Any help would be appreciated.
    Dec 2003
    24220
    You would requires some kind of drive that can accept a commutation signal. And use the correct commutation detectors, phased correctly, it looks like they supply these.
    Also the rotor is P.M. so some kind of BLDC drive is required.
    To use them in any other simpler fashion you would have to feed the three windings with three phases and make a squirel cage rotor/armature in place of the PM, but this may not be feasable.
    Al.
    Albert E.
  1. router motors speed
    By vwdevotee in forum CNC Machine Related Electronics
    Last Post: 11-14-2006, 06:02 AM
  2. Position control of brushless AC servo motors
    By mackeym in forum Servo Motors / Drives
    Last Post: 09-10-2006, 10:55 PM
  3. BLDC control software
    By t305100 in forum CNC Machine Related Electronics
    Last Post: 08-26-2006, 12:36 AM
  4. BPSeriesI / Centroid control- Spindle speed all out of whack with speed dial?
    By peter.blais in forum Bridgeport / Hardinge Mills
    Last Post: 08-08-2006, 09:29 AM
  5. Changing the speed of DC motors
    By creative_mind in forum Community Club House
    Last Post: 12-02-2003, 02:27 PM
