Good mist coolant/lube for 5052 AL?
Anyone know of a mist compatable coolant that works well when cutting 5052? So far KoolMist is not getting it done. It seems to work ok for drilling but the minute an end mill is involved there is so far only one solution and that is WD-40 and LOTS of it. As long as I bathe it in WD-40 it cuts nicely but as soon as that stops there is vibration, heavy burrs, and tool breakage if you let it continue with just mist.
I'm taking the feeds-n-speeds from G-Wizard and so far I have not found any combination that is signifcantly better.
I'm doing a ton of thin plates (1/8" or thinner) as brackets for my robot and the place I get my Aluminum from locally only has this bubble gum crap 5052 for anything less than 3/16" thick but for what I need it works fine once cut. I'd hate to have to start ordering and shipping all the plate but if I can't find a way to make cutting this stuff less butt-puckering I'm going to have to. 6061 cuts great with KoolMist
CNC: Making incorrect parts and breaking stuff, faster and with greater precision.
