587,220 active members*
2,511 visitors online*
IndustryArena Forum > MetalWorking Machines > Okuma > Partoff Blade Tool Holders
Results 1 to 12 of 12
    Dec 2014
    10
    We have a partoff blade holder from velocity but its only .16 wide and we are wanting to use a blade that is .250. does anyone know another brand that offers wider blade holder? what do you do when you have to part off larger diameter materials?
    Aug 2011
    2517
    Re: Partoff Blade Tool Holders
    Iscar make the best parting tools and they have a wide range of holders and blades. check them out at www.iscar.com
    Apr 2009
    1262
    Exsys has a kick butt cutoff blade system. It uses Iscar blades too. Which machine are you on?
    Dec 2014
    10
    we are using an iscar partoff blade but the holder is from velocity. it bolts directly to the turret and is L shaped to allow the spindles to get closer together without interference. our machine is an LB3000EX MWY. but like I said, the space for the blade is only .16 wide and we are wanting to use a .25 wide tool.
    Apr 2009
    1262
    I believe the Exsys can handle the thicker blade.
    Best regards,
    Dec 2014
    10
    I checked them out and I only saw a holder for a blade 26mm tall. the blade we are using now is 32mm tall and 6mm wide
    Feb 2009
    6028
    Quote Originally Posted by fordav11 View Post
    Iscar make the best parting tools and they have a wide range of holders and blades. check them out at ISCAR Cutting Tools - Metal Working Tools - Precision Carbide Metal Working Tools - Metal Cutting Applications
    +1
    Dec 2014
    10
    we have Iscar blades and a holder. im looking for a cutoff tool station that mounts to the turret and only holds a cut off blade. the holder is L shaped and bolts directly to the turret. I work very close with my Iscar rep and they do not offer what im looking for. Velocity has one but not quite what im looking for.
    Dec 2014
    10
    Quote Originally Posted by OkumaWiz View Post
    its an LB3000EX MWY. I checked out Exsys but the only holder I found for this machine will only hold a 26mm tall blade and we are using 32mm tall and 6mm wide
    Feb 2009
    6028
    Why would you want a thick blade, i mean the LB has what, a 3" through bore? Just get a .125 with coolant feed through and never look back.
    Dec 2014
    10
    ya it does but anything bigger than 4" OD is too much for the blades we have been using. that's why we got a thicker blade
    Aug 2011
    2517
    check out WTO. they make tool holders that bolt directly to turrets, including L-shaped part-off holders. http://www.wto-usa.com
  1. Replies: 1
    Last Post: 12-22-2014, 06:35 AM
  2. Replies: 0
    Last Post: 11-03-2013, 04:02 AM
  3. CNC Tool Library (Creation of ISO 30 Tool Holders)
    By ender_wiggen in forum SolidCAM for SolidWorks and SolidCAM for Inventor
    Last Post: 01-27-2012, 08:59 AM
  4. Replies: 4
    Last Post: 01-02-2009, 10:55 AM
