Re: M151 Holding piece in both chucks and lathe from Second chuck. HOW?
hy manhtranc
t
hey want me to turn .... a part between both spindle
both spindles must have found their S origin, so jog each spindle ( or turn each one by hand ), just a couple of revolutions, like 2-3 max spins, so to get rid of CD****
manual mode, clamp your part with both chuck
G140
G50 S2000
M151 M210 M883
G97 S250 M03
if it works, then continue with normal turning codes
and milling a part between both spindle
manual mode, clamp each chuck with individual parts, thus don't use long part yet
G140
M110
M892
if it works, then more codes and parameter related to C origins, are needed before using normal milling codes ( i will try to help you with them ); if it does not work, pls share error and image with setup ( will try an alternative method ) / kindly
