Hello, I'm trying to figure out how to configure the g-code output from SolidCAM so that it will work with my lathe. When the software posts code, the x-values are in diameter mode instead of radius, and they are positive instead of negative.
In other words, if I am turning a 2"OD bar on it's outer surface, the post says this is x2.0 since it's 2" diameter. What I want it to say is x-1.0 since it's 1" radius and on my machine I need to use negative numbers.
Any help would be appreciated. Changing to radius mode is the bigger issue. If I have to turn all the X values to negative (just by editing the g-code text file) manually that's not a big deal but cutting them all in half manually is a much bigger pain.
