587,744 active members*
2,954 visitors online*
Results 1 to 3 of 3
    May 2008
    667
    Bobmill MK3 VMC
    Hi, for some time I want to buy a small VMC.
    Just found from this company Majestic Machinery VMachining
    a small VML mill.
    This is the BobMIll model but with ATC, servo motor full enclosure is available.
    This is the big brother of the MK2 model, it's the MK3
    BT30 spindle with 5 HP motor up to 6000 RPM but a more powerful spindle is also available.
    Linear axis for X, Y and Z.
    Coolant pump.
    Rigid Tapping is an option
    22 3/4 of travel for X axis at 750 IPM rapid
    Just included the PDF for all the specs.
    Just would like to know what you think about this machine.
    Any owner of the MK2 series, please tell me about your experience.
    Please, I want to have your tough about it.
    Thanks a lot, Jeff
    Attached Files Attached Files
    May 2008
    667
    I'm surprise, I tough this would be an interesting post about an affordable cnc.
    Jeff
    Oct 2014
    6
    Re: Bobmill MK3 VMC
    i got mk2 , still playing with it, using mcb1 from industry controls and stepper smoother , it came 3 phase , only the spindle vdf is 3 phase in also the atc motor other than that drivers can work also in single phase 220 , high quality balls screws with linear slides
    on mach3 , I just love it , soon will have it running on single phase 220vac, BUT the problem is that I contacted industry controls to get some manuals on the board sadly it seems no answer , i might end up installing new board if i do not get support for it. I hate that but stuff happens
  1. The new BobMill 2300
    By choppero in forum Uncategorised MetalWorking Machines
    Last Post: 11-18-2009, 05:12 PM
