Hello guys.
I am looking for a bit of guidance on a problem with an A06B-6120-H045 power supply module.Sometimes when I switch on the power isolator the power supply does not switch on (no led on)..Am I right to think that if the 240v input is there the led should light up and when the control is switched on the drives should enable.If this is the case what area of the PS should I be looking at for a fault
Dean.
