CNC Drag Knife
Got a new one out:
Adjustable Offset Drag Knife
![](https://cosmos-industrial.com/images/3005-300.JPG)
Adjustable Offset: 2-12mm (~1/16 - 1/2”)
Blades: Any standard sized utility blade. This lets you use HSS, Tin coated or Carbide edged blades.
Set screw is used to recall offset position between blade changes.
Body: Gray anodized 7075 Aluminum (high strength). 62.3mm long (not including blade stick out)
Bearings: Dual 7/8” diameter ball bearings offer best balance between radial load capacity and minimal overall length
Shank: Hardened steel 3/8”. 36.2mm length.
Clamp: 303 stainless steel. M5 bolt
Made in Fort Worth, TX
Days to ship: 1-2 (usually same day)
cosmos-industrial.com Pen Marking Tools and CNC Drag Knife
