603,822 active members*
3,557 visitors online*
Results 1 to 3 of 3
    Feb 2010
    Drip feed or DNC
    Im running large programs on a Mori-Seki SV503 and would like to know if there is a way to run programs directly from the memory card.
    Thank you,
    Larry
    Feb 2006
    992
    Yes, but the problem you will run into is RS232 will stop working. It's pain in the behind to switch back and forth, the setting for memory card and RS232 is the same page and the setting quite difference.
    The best way to learn is trial error.
    Feb 2009
    6028
    I don't have the procedure here, but yes you can. SV503 is a Maps control, so I would call the dist. (probably Ellison) they will have a procedure they can fax to you. We used to do it all the time.
  1. DNC-B to use drip feed
    By 78nova in forum Okuma
    Last Post: 02-02-2010, 08:21 AM
  2. drip feed
    By kirby in forum Fanuc
    Last Post: 11-29-2009, 03:04 AM
  3. Drip feed, DNC?
    By Greg_B in forum Mastercam
    Last Post: 05-20-2009, 05:31 AM
  4. Drip Feed
    Last Post: 10-20-2008, 03:21 PM
  5. BMC-20 w/Max II drip feed......
    By GPena in forum HURCO
    Last Post: 10-31-2007, 06:37 PM
