603,796 active members*
3,620 visitors online*
Results 1 to 12 of 12
    Jul 2009
    85
    Need turned from Ertalyte TX, school project
    I have few parts, that I would like made. I designed for a project at Toledo University for a engineering class. I worked as a cnc programmer for two years so, the parts are machining friendly.
    Parts are only 5.5 inch long and the major dia is .72. All dimensions are in inch.
    Most tolerances are +-.005 I have couple tight tolerances +-.001 and couple +-.01
    Stock would 1 inch dia Ertalyte TX. You would have to get that
    You would need a cnc lathe with a milling head or set up parts to be turned then milled.
    I will be coming back to you for more work.
    I need 3 made
    If you are interested on making these for me, send me a pm on here or email at [email protected]
    I will pm you or email you the print
    Jan 2008
    449
    Been machining for 30 years and never heard of that material. I think you should
    put up a better description of your part. It could be a screw machine part with that length to width ratio and needing such a machine would eliminate 95% of the people who bid work here, it would save you some time sending out prints to people who can't assist you.
    Jun 2005
    1015
    we have turned ertalyte for other projects. the material is not cheap but we can get it. and we are located in sterling heights. i will email you for a print.
    15362
    Dualkit
    This material is like a good replacement for Delrin AF, if you have ever used the AF you will know that that is a great material as well, but not used by many,
    Ertalyte is a high strenth, high wear & good up to 200F deg a very nice material & can be machined any way you want
    Mactec54
    Jul 2009
    85
    Its a lathe part for sure. I have made one on mazak quickturn, toke way to long to get it my self. I have to study and million other projects im working on.
    Yes good its a good replacement for derlin af. That was my orginal material but i found Ertalyte TX would be much better for my needs.
    I will show you what part is
    (green moving piece)
    Sorry only sawing the print if you pm me or email
    A certain paintball company is stealing design
    Jul 2009
    85
    I did changed some stuff the final print will done asap
    Aug 2006
    674
    I've very disapointed you didn't contact me on PBN! you know i can make these for you...
    Jul 2009
    85
    I did you never answered me
    Nov 2008
    61
    Im a college student myself and own a CNC shop. Send me a email. I have a lathe with live tooling available.
    dennisrathi[at]gmail.com
    Creations Unlimited
    Morgan Hill, CA 95037
    Jul 2009
    85
    Quote Originally Posted by dstryr View Post
    Creations Unlimited
    I will send you email
    Update this parts only needs be turned out of 6061 AL
    Nov 2008
    61
    Never got your email?
    Apr 2010
    hiii
    Best Attorney
  1. Bridgeport CNC Series 1 School class Project
    By electromech31 in forum LinuxCNC (formerly EMC2)
    Last Post: 04-24-2009, 06:18 PM
  2. High School Project - Jewelry Box with Inlays
    By Sbthomas13 in forum WoodWorking Topics
    Last Post: 03-21-2009, 03:14 AM
  3. School project; Building our own CNC-machine
    By st3roid in forum European Club House
    Last Post: 02-20-2008, 10:40 PM
  4. School Project
    By Strider2006 in forum Mastercam
    Last Post: 12-10-2006, 12:20 AM
  5. Desperately NEED HELP FOR SCHOOL PROJECT
    By Epik in forum Uncategorised CAM Discussion
    Last Post: 12-09-2005, 12:06 PM
