587,517 active members*
3,036 visitors online*
IndustryArena Forum > MetalWorking Machines > HURCO > Pins for km3p amphanol plug to servo motor
Results 1 to 2 of 2
    Does anyone know where to get the pins for the amphanol plug that plugs into the servo motors? What is the part no. for the pins?
    Thanks for any help
    Aug 2014
    17
    Re: Pins for km3p amphanol plug to servo motor
    Not sure but I think it is Amphenol 206044-1 cable end, Amp 206043-1 bulkhead. For future reference.
    I got them and these numbers are good. If you do the search and poke around a little, you should find the pin numbers. Please share if you do as I might need to order some also.
    This should help
    https://www.newark.com/amp-te-connec...e-17/dp/46F320
  1. Replies: 1
    Last Post: 04-22-2021, 01:31 PM
  2. Mach 3 randomly changes motor pins to 0
    By Bama5150 in forum Mach Software (ArtSoft software)
    Last Post: 03-10-2019, 01:53 AM
  3. Another Plug and Play servo controller thread.
    By rhino in forum Controller Cards
    Last Post: 04-18-2015, 03:24 PM
  4. Replies: 1
    Last Post: 10-05-2011, 02:39 PM
  5. Info needed on Servo for KM3P
    By freak_brain in forum HURCO
    Last Post: 02-11-2009, 05:17 PM
