603,365 active members*
3,028 visitors online*
Results 1 to 11 of 11
    Mar 2008
    95
    Overdriving the spindle with a VFD on a 2J
    Anyone running a VFD on a 2J head? How fast can you/do you you run it? Right now I have mine set to 75 htz and is seems to hum along nicely. How fast is safe for the motor? Where do you leave the belt speed set at?
    Thanks!
    Feb 2006
    7063
    Quote Originally Posted by rogerfries View Post
    Thanks!
    My machine is not a Bridgeport, but a Chaiwanese clone. I routinely run for hours on end up to 90Hz/8200 RPM with no problems whatsoever. It's a two-speed motor. In low speed, I'll run up to 120Hz.
    Regards,
    Ray L.
    Dec 2003
    24260
    Quote Originally Posted by HimyKabibble View Post
    How do you manage that Ray?
    A 2 pole motor at 90hz would be <5400 and <7200rpm at 120hz?
    Unless that is the output rpm and you are geared up by belt etc.
    If four pole motor it would be half that rpm.
    Al.
    Albert E.
    Feb 2007
    198
    The varidrives gear up.
    How hot does your quill (bearings) get Ray.
    I have run mine at 5500 and after 10 minutes it is quite
    warm with no load on the bearings.
    May 2008
    132
    I run my BP at 120Hz about 5400 RPM on the spindle and it gets a little warm but not to the point I woud worry.
    Ray:
    The new job must be keeping you busy, not seen much from you lately.
    Quill Drive is working great but progress on the rest of the mill has been slow.
    Craig
    Feb 2007
    198
    Do you have the packed grease bearings?
    I wonder if mine runs warmer because of the packed grease.
    Feb 2006
    7063
    Al.
    It's a step pulley machine. With the motor in high range (2-pole), high-speed pulley, 60Hz, the spindle turns 5440 RPM. At 90Hz, that's 8160 RPM.
    Regards,
    Ray L.
    Feb 2006
    7063
    Quote Originally Posted by polaraligned View Post
    I've run mine at 8200 RPM for hours at a time. After 2-3 hours the spindle will be up to maybe 110-120F - not hot enough to be a problem.
    Regards,
    Ray L.
    Feb 2006
    7063
    Quote Originally Posted by 79TigerPilot View Post
    Ray:
    Craig
    Craig,
    Haven't so much as turned the machine on since Feb, and don't anticipate being able to do so any time soon...
    Regards,
    Ray L.
    Feb 2006
    7063
    My understanding is, for a high speed application, you want to only fill the spaces between the balls only about 20% with grease, not pack them. I have no idea how mine are setup - I've never touched them since I bought the machine about 3 years ago.
    Regards,
    Ray L.
    Feb 2007
    198
    Thanks Ray.
  1. 1992 VF2 Alarm 123 spindle Spindle Drive Fault
    By dafowfidy in forum Haas Mills
    Last Post: 05-14-2012, 07:32 PM
  2. spindle motor and spindle control dont work
    By customcncparts in forum Milltronics
    Last Post: 10-01-2009, 08:08 PM
  3. Sweo spindle drive? new mill dead spindle
    By Shizzlemah in forum Fadal
    Last Post: 12-18-2008, 06:11 PM
  4. Overdriving a stepper motor
    By RChadwick in forum Open Source Controller Boards
    Last Post: 08-01-2008, 07:56 PM
  5. Lathe spindle bearings and spindle material
    By mackeym in forum Linear and Rotary Motion
    Last Post: 08-11-2007, 04:53 PM
