HAAS VF3
It has been awhile, but I am climbing back into the seat. I am working out some serial connection issues with the machine, but I did drop in code to the machine via floppy disk before.
I am starting with some simple engraving. When I generate the code, each line has N #'s , and code I generated years ago does not. I have selected the HAAS VF series for the NC config. Should I select something else?
Also, aother dummy newbie question. How do I set the z depth globally in the code.
Thanks,
Try not. Do. Or do not. There is no try.
