603,797 active members*
2,595 visitors online*
Results 1 to 6 of 6
    Feb 2005
    753
    Sanding a mould
    Hi, I made a mouse that I am going to lay fiberglass over. I just wanted to know how you guys sanded down your moulds. It is made out of 6061 aluminum.
    Please help. I got all the tool marks out with 100 grit now I need to get a mirror finish.
    you got to step it up to 1000 grit, then buff with a good quality paste for polishing
    Feb 2005
    753
    I got 1200 grit and mothers aluminum polish. Good enough?
    Aug 2004
    421
    You should have a step between 100 and 1200 or you will be sanding all day. 320, 600, etc. The mothers polish works good after the 1200, fine steel works good also for detailed stuff.
    If you try to make everything idiot proof, someone will just breed a better idiot!
    May 2005
    1810
    Tip -
    When you get above 220 grit use water to keep the paper from plugging, which can ruin your work.
    After about 600 grit, I would go with a cotton buffing pad on a die grinder if your part/mold will allow it - too much aggression and you can loose/blend fine detail.
    Scott
    Consistency is a good thing....unless you're consistently an idiot.
    Jul 2005
    5
    Use steps in the paper, i usually go 80, 320, 600, 1200 and then autosol for a mirror polish, but use WD40 to wet the paper or else it clogs the paper up. Before you mirror polish it make sure youve got rid of the crap and WD by using a degreasing aerosol like TF90.
