Originally Posted by
bmx4637
ok I think I'm gona go with the RhinoCAD w/ Rhino CAM plugin. what kind of cnc software is out there besides mach3 that is good and affordable? and is is difficult to transfer the files to g-code on the cnc?
[If you want to stick with the Windows platform, the only other CNC control program I can think of is Flashcut, which is considerably more expensive, and requires dedicated proprietary hardware. If you want to go Linux, then there's EMC, which is free but somewhat difficult to set up, especially if you're unfamiliar with the OS. If you can handle DOS, then there's TurboCNC and CNCPro (although I haven't heard much about that one lately.)
It's not hard to load a G-code program - it's basically just a text file. Of course, if you want to load them from a network or USB stick, then using DOS might make that difficult...]
And I plan on working with aluminum primarily, some wood, and some steel.
[That shouldn't be a problem for the software, if your machine's up for it.]
(edit) oh, and I know this goes into another thread but I'm just going to throw it on here. I would like to have 4-axis capability. I believe I am going to make the machine to lower the cost a lot. Any Idea where quality parts are sold at?
