587,458 active members*
4,068 visitors online*
IndustryArena Forum > MetalWorking Machines > Milltronics > Milltronics VM16 Cent V
Results 1 to 3 of 3
    Apr 2011
    Hi all
    New to Milltronics but got a good deal on a machine so I bought it. I am having a problem with the x axis. It cuts small in comparison to Y, I tried adjusting the scale factor in the parameters but no change. I am running G-code programs so that may be why the parameters didn't change anything. The scale seems to be off about .0012 per inch. Any help would be appreciated.
    Oct 2008
    427
    Is the error consistent for all moves? A 2 inch move gives a .0024 error, a 10 inch move gives a .012 error, a 20 inch move gives a .024 error, etc?
    If so, it could be several things: a bad encoder, a bad Ball Screw comp table, the wrong PPU parameter, bad motion control, etc.
    If not, positioning problems are frequently backlash problems: bad or loose thrust bearings, bad or loose ball screw or mounts, loose or worn drive belt or sheaves, etc.
    Good luck finding the problem.
    Jul 2010
    548
    Muttley 69
    Any updated info from ZZZZ questions?
    On your G code programes, are they posted from a CAD/CAM?
    If the rate of change stays the same, .0012 accross the travel I would suspect a bad thrust bearing / backlash problem.
    We neeed more info
    questions? just ask
    sportybob
  1. Milltronics VM16 not homing.
    By Ciaran in forum Milltronics
    Last Post: 02-22-2011, 02:10 AM
  2. Connecting Desk top to 1997 Milltronics VM16
    By SpeedMetal in forum Milltronics
    Last Post: 02-01-2008, 10:56 PM
  3. Replies: 8
    Last Post: 11-15-2007, 06:16 PM
  4. VM16 Info
    By elecbeaver in forum Milltronics
    Last Post: 06-23-2007, 01:34 AM
  5. VM16 CNC shutting down
    Last Post: 05-22-2007, 12:22 AM
