587,168 active members*
3,353 visitors online*
IndustryArena Forum > CAM Software > Mastercam > Creating STL files
Results 1 to 2 of 2
    Apr 2010
    Creating STL files
    Question see attached link and zoom in on the the typographical map
    InciWeb the Incident Information System: Duckett Fire
    How can you save this number one, how can yo convert this to an stl file so you can do a mountain range profile ?
    May 2004
    4519
    I do not think this can be done the way you are thinking. You can get a raster image and using the Art function, you can find "contours" and then assign "Z" depth values to the apparent "contours". This process would be both extremely time consuming and probably very inaccurate. You would be better off to locate a geo-survey file in vector format and work from there.
  1. Converting Illustrator files to Gcode files
    By acoop101 in forum Uncategorised CAM Discussion
    Last Post: 03-10-2023, 11:13 PM
  2. Creating TAP files from Notepad
    By ViperTX in forum Mach Mill
    Last Post: 03-16-2010, 02:05 AM
  3. Replies: 2
    Last Post: 03-09-2007, 08:47 PM
  4. Creating surfaces from .iges files
    By homebrewCNC in forum Mastercam
    Last Post: 09-10-2006, 05:27 PM
  5. Creating .dxf files
    By lal19541 in forum Uncategorised CAM Discussion
    Last Post: 08-31-2006, 07:40 AM
