603,326 active members*
3,194 visitors online*
IndustryArena Forum > MetalWorking Machines > Hyundai Kia > SKT 21 LMS OI-TB STOPS AFTER CHANGE TO LIVE TOOL, MUST PUSH START
Results 1 to 2 of 2
    Aug 2019
    9
    Oi-Tb HYUNDAI KIA SKT21LMS when it selects a live tool, makes the tool change, and comes to the G97 Sxxx M13 block, machine acts like M1 is active. It stops and the start button must be pushed. It only does it after a change to a live tool. Multiple ops with the same live tool it will complete the op, stop the tool, return the turret and perform the next op without an issue. This may be some sort of safety after a live tool change, but when doing a bar fed run of parts that have 3 or 4 different live tool ops its pretty inconvenient as it won't run unattended. Does anybody know a code, or the parameter that may need changing, to let the machine continue without the start button being pushed? See Code below.
    Fixed tool first:
    N3(POCKET CENTER DRILL 2)
    G0 G53 B0. (SUB SPINDLE RETURN)
    G28 U0.
    G28 W0.
    G54
    G99 M40
    T0505
    G97 S3200 M3
    G0 Z0.62
    X0.
    M8
    G80
    G0 Z0.22
    G83 Z-1.404 R-0.02 F0.007
    G80
    G0 Z0.62
    M9
    G28 U0.
    G28 W0.
    M1
    CHANGE TO LIVE TOOL
    N4(LUBE HOLE DRILL1 5)
    G28 U0.
    G28 W0.
    M111
    G54
    G98 M43
    G0 G28 H0.
    T1212
    G97 S3000 M13 MACHINE STOPS HERE, START BUTTON MUST BE PUSHED
    G0 C90.
    G0 Z-0.6845
    X3.7
    M8
    G0 X2.9
    G87 X1.3393 R-0.1289 F11.459
    G80
    G0 X3.7
    Aug 2019
    9
    Re: SKT 21 LMS OI-TB STOPS AFTER CHANGE TO LIVE TOOL, MUST PUSH START
    25 views and no reponses. Come on guys, any suggestions at all?
