603,392 active members*
3,344 visitors online*
Page 1 of 3 123
Results 1 to 20 of 49
    Nov 2011
    50
    newbie needs help with laser alignment
    Hi I have a k40 chinese laser engraver and I have been trying to align the beam as I got new reflective mirrors. I can't figure out how to align the second mirror. When it's closets to the tube I set the beam to the centre of the mirror but when I move it far away the beam is now off the mirror bracket to the left. If I set the beam here and move it faward the beam is no longer in the middle. How do I align the mirrors? Any help please.
    Thanks Dom
    Nov 2008
    382
    Hi dominic
    first prepaire you for a while of twiking.
    what you have to do is like my system: i cut out of 1/8 pressboard squares in the size of the outside of the holder ring, then I put two stripes of tape on the piece and stick the hole thing on the holder ring and tape to the back, ( this prevents the mirror from damage because I dont remove the mirror)
    the first wher you do this is the mirror right next to the laser tube and shoot a beam the brown point should be around the middle of this mirror .I marke the middle of the press board with a compass.
    then you go on the Y axis and put the press board on this holder ring and move them to the back ( closest to the tube ) and shoot a beam put the settings on about 6 to 8 % shoot just as much that you can see the brown spot it shoud be somewhere around the middle and marke it
    then you slide this mirror ( gantry mirror) to the front of the machine
    ( the farest from the laser tube) and shoot another beam see where it lands
    now comes the tricky part you have to adjust the 1st mirror closest to the laser tube to get right on the on the first ( marked spot)
    now go back and forth and see if the spots are allway on top of each other.
    this way you have alligned the Y axis and take the pressboard off
    now you take a piece of tape and put it right on top of the laser head opening move the Y axis to the back and shoot a beam and see where it lands if you dont see any brown spot take a 2inch stripe about 5inch long and hold it just in front of this openeing and shoot a beam maybe shoot a second time this way you see where it lands now come the fiddleling what could take a long time.
    to adjust the laser head mirror you have to use the set screws on the second mirror ( gantry mirror) but be carefull dont turn to much just play a bit to see how it works the brown spot should be here around the middle of the openeing on the laserhead, marke it
    then move the Y axis to the front of the machine and shoot another beam.
    if you are lucky it the two spots are exactly on top of each other if not you have to use the gantry mirror setsrews to bring the second spot right on top of the first one
    after they are right on top of each other ( just be paitient) then move the laserhead to the right rear corner and shoot a beam again this should be exactly on top of the other two if not you have to use the gantrymirror setsrews again bit just very little ( on some machines a turn of 1/16 is allredy to much)
    now you have to go back after adjusting this spot to the first position left rear and check the spot if it is still there
    after all this matches you have to go to the front right corner and try the spot there and do the same like on the other spots .
    like I said be patient you will get it right.
    my first time took me 4 hours. but now I do it in 20 min.
    I hope this helps
    greetings
    walt
    Quote Originally Posted by dominic gailgan View Post
    Thanks Dom
    Hiya Dom,
    If the beam is striking mirror one in the centre then mirror two in the centre but off centre as mirror two moves away then the tube isn't aligned.
    To get spot on alignment the tube has to be @ 45 degrees to mirror one when the mirror is @ 45 degrees to the slideways.
    Basically you are looking to have the tube at the same level and paralel to the cross slide (the left to right slide) to get perfect alignment.
    The machine will work and will cut over the entire table if the tube is out but you will always be chasing your tail.
    get the tube correct then alignment becomes so much easier in future.
    best wishes
    Dave
    Nov 2011
    50
    How do I align the tube? I can't see any way of moving the tube. The beam does move off centre as it moves away. But how to fix this I'm not sure of. Help please.
    Thanks Dom
    Hiya Dom,
    I'll write it up in detail with pics in the morning for you
    best wishes
    Dave
    Nov 2011
    50
    Any help will be good. Just had another look at this. I can set the first 2 mirrors but when I go to set the laser head I have a 40mm difference between the closest and the far away movement. I don't understand how to set set the beam in the same spot at all y axis extremes. It's not the mirrors, just put new ones in. I'm beginning to wander if this machine is fatally flawed as so many people complain about the poor build quality of the machine. And as there's no manufacturer's name on it I can't ask any body for technical support.
    Nov 2011
    50
    I have just noticed that the second mirror and the laser head are not in the same line. The head is 7mm closer to the tube than the mirror? Is that a problem? There's no more adjustment in the laser head. And there's no front back adjustment in the mirror bracket. Can I use a visible laser light to set the beam? If so how do I use it?
    Thanks Dom
    Yup thats a big problem Dom, it means you will have to move the tube, could you take a picture of the tube clamps and their bases as the entire clamp is going to have to be moved.
    I've been writing up some stuff on this today but I am concerned that over movement of the tube could result in the beam going just about anywhere and the last thing I would want is for somebody to end up blinded by instructions I post.
    Most of all you will need eye protection suited to the 1064nm wavelength of the laser you have. This is one case where shortcuts can proove very nasty.
    best wishes
    Dave
    Nov 2008
    382
    Hi dom
    what di you mean by 7mm closer to the tube as the second mirror?
    if you have adjusted the second mirror in the way that the beam is the same place in the front and the back of the Y axis thats ok
    then in order to make sure that the laser head is in the same line as the second mirror ( that the beam is exactly in the mittle of the laser head mirror opening) you should take out the mirror from the head put a 10mm round with a perfect tip thru it and measure the distance from this toward the gantry it must be exactly paralell and the tip of the round needs to be in the center of the second mirror.
    if the round shows that is not paralell then you need to losen the head holder ( pair of chanel plier to unscrew) and twist them that its perfect paralell, if the round tip is out of the center of mirror 2 then loosen the 3 screws on the head carrier plate and adjust it towards toe front or rear .
    only then if this is is still out of any of the critical points then you have to move the tube , but in most of the cases what I had this was all what needed to be done
    greeitngs
    walt
    Thanks Dom
    Nov 2011
    50
    Thanks for the replys. Look at the photos. The one shows what I'm talking about the mirror and head not being lined up.
    Attached Thumbnails Attached Thumbnails laser mirror and tube photos 001.jpg   laser mirror and tube photos 002.jpg   laser mirror and tube photos 005.jpg   laser mirror and tube photos 006.jpg
    Nov 2008
    382
    Hi dave
    I have to disagree with some :
    first it is right that the beam needs to be exactly in the center of mirror one
    but then the beam on mirror two would be adjusted with the setscrews of mirror one in direction gantry rear and front head on the left side.
    then the head would be adjusted with the setscrews on mirror two the gantry to rear and front head to the left side then gantry to the front and rear and head on the right this takes a while like described before.
    thats the way how the industrie adjust the beam .
    the tube only needs to be moved when:
    the hight of the beam is completly of center on mirror one
    thats the best way to adjust the beam
    greetings
    walt
    Quote Originally Posted by Exsecratio View Post
    Hiya Dom,
    best wishes
    Dave
    Nov 2008
    382
    hi my friend
    you can not measure this way you have to put a 10mm rod in the opening of the leaser head and then see if the tip is center with mirror two the mirror surface is what counts not the holder.
    the beam burn what you show is pretty much perfect now it only needs to be the same point if you move the laser head to the rear then front then right front - then right rear if the brun mark is every where the same you got it if not you need to adjust with the set screw on mirror two it takes a bit of fine feeling especially with the right side a 1/8 turn could be already to much
    with the settings make a test engraving ( a picture or so)
    and post it
    then we can see how it works
    greetings
    walt
    Hiya Walt,
    I'll run up a quick drawing to explain what I mean
    Dom, the extreme way out the mirror two seems to be doesn't look right, BIG gap between the mirror and holder but I see what you mean about them not being in the same plane...
    Gimme an hour guys and I'll have a pic up
    best wishes
    Dave
    Nov 2011
    50
    I can't set the beam in the laser head. If I set it close to the mirror in front left or back left that's fine. But when I move it to far left front or back as the picture shows the beam has moved so much. I set the beam in the middle and then move the head back close to the mirror the beam has moved about 10mm towards the tube. There has to be something wrong here. I can't see how you can adjust out this movement with the adjustment screws on the mirror.
    Can I use a visible laser light to test the beam path?
    Nov 2008
    382
    hey my friend believe me the only way to adjust it is with the setscrews I have adjusted many machines
    like I wrote before it takes a long while the first time.
    the best way is to watch how the beam moves by using a strip off thin board or so hold it right in front of the laser head so that on both sides are about 30mm standing over shoot a beam , then turn on the adjustment screw top left about 1/2 turn in shoot another beam look wher it hits the strip and so on.
    the top screw moves mainly to the right and left on the laserhead the right screws move the beam up and down but if you are close then you need to use all three screws to fine adjust also on the right side of the gantry rear and front.
    but allways start with the head on the left and in the rear adjust the beam that it is about in the center off the hole in the head. then move the gantry to the front and adjust that the beam hits exactly the same spot then you move to the right front and adjust again then to the rear right asnd adjust again
    allways for this adjustment just use the setscrews on mirror two.
    greetings
    walt
    In the case of the left the beam strikes the middle of all mirrors and will still do so,no matter where the head is on the table
    In case 2 on the right the beam still hits the middle of all mirrors BUT will only align in one place in any given axis as the tubes emitter isn't parallel to the gantry.
    Unless the tube is parallel to the gantry simple geometry will show it is not possible to align the beam other than in one place.
    The extreme adjustment on the mirrors suggests something is out of line, I'd get all the mirrors back to a close starting position then see if you can adjust Dom, the mirror being stuck out so far in the pics isn't right.
    best wishes
    Dave
    Nov 2011
    50
    Evan though there's so much movement in the beam can I adjust it out with the mirror screws? I have tried stopping the head in the middle then at the far right but have found that the beam moves just centermeters away. Again I say I can't figure this thing out. I've been going at this now for 4 weeks now.
    Nov 2011
    50
    I can't set the beam. It doesn't matter what I do the beam moves so much between the left and right positions. Could there be a problem with the position on the 2 mirror and the laser head? As the mirror bracket is home made. I don't think the tube is out because I can set the beam between the two mirrors but not between the second mirror and the laser head. How do I know when the mirror and laser head are lined up? Look at the pictures already on this post as they show the mirror and the laser head are not parallel. Can I use a visible laser light to check the beam pat especially between the second mirror and the laser head?
    Nov 2008
    382
    OK my friend
    it seems you have a bigger probleme what has to do with shady workmanship.
    now take a 6 inch square and sqlook if your whole mechanic setup ( frame is square to the rear wall of the cabinet ( I had this in a couple cases wher it was out of square from wrong assambling or transport) if you need to correct it loose the four screws who hold the frame in the cabinet two in the rear and two in the front thenn correct the square and re tighten the screws.
    next take the square place it on the left side of the Y frame and against the gantry look if this is exactly square and do the same on the right side if this is out of square loosen the coupler on the Y axis stepper motor and pull the left side to the right position not the right side because there is the motor with the belt the left side is loose now after putting the gantry exactly square hiold it there and tighten the couple screws not you should have everythings correct. and can start adjusting the beam again
    greetings
    walt
    Nov 2008
    382
    hi there
    here are two picture about alignement of laser head.
    the laser head needs to be perfect paralell to the gantry use a 10mm round to check this, the point og this rod needs to point in the center of mirror 2
    greetings
    walt
Page 1 of 3 123
  1. Laser spindle alignment?
    By cgallery in forum DIY CNC Router Table Machines
    Last Post: 12-22-2014, 01:01 AM
  2. Newbie alignment issues
    By mooreaa in forum Tormach Personal CNC Mill
    Last Post: 01-08-2012, 12:32 AM
  3. Laser alignment (bad focus lens?)
    By fantasy2 in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 10-21-2011, 06:44 PM
  4. Laser Beam alignment
    By graver1 in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 01-24-2011, 05:48 AM
  5. Replies: 1
    Last Post: 12-09-2010, 08:15 AM
