603,804 active members*
3,023 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Fanuc > change zero point C axis in program run
Results 1 to 5 of 5
    May 2011
    81
    Hello everybody
    I know that it’s possible to set the zero point over the parameter with older Fanuc controllers (#2501=#5021 set neutral point X axis)
    Now I would need the parameters for the C axis of the above named controller ( 5 axis with A and C axis)
    I would like to change the zero point of the C axis several times during a program run- as it would save a lot of programming time.
    I hope I expressed myself in a comprehensible manner and I am quite curious to find out if somebody can help me put!
    Kind regards
    SV20 relative absolute
    X #5021 X#5041
    Z1 #5022 Z1#5042
    A #5023 A#5043
    Y #5024 Y#5044
    B #5025 B#5045
    Z2 C2 #5022 C2 #5042
    E C2 #5023 C2 #5043
    Revolver C2 #5025 C2 #5045
    SR20 relative absolute
    X #5021 X#5041
    Z #5022 Z#5042
    Y #5024 Y#5044
    XB C2 #5021 C2 #5041
    ZB C2 #5022 C2 #5042
    I am not quite sure if that helps you out!
    May 2011
    81
    Hello
    Thanks a lot for your help. Unfortunately I don’t know at all what that means =(
    Maybe you could explain it to me??
    Kind regards
    Hello
    I know setting/moving the zero point in the program with G10.
    e.g. G10 L2 P1 X.. Y.. Z.. C..
    or incremental G10 L2 P1 U.. V.. W.. H..
    P1=G54, P2=G55 and so on..
    So "G10 L2 P1 H90." turns the zero point of the C axis in G54 around +90 degrees.
    Nov 2005
    63
    Are you working on a milling machine? I don’t know that at all... I mainly program incremental anyway but if you don’t want to move it permanently and only in the middle of the program then it’s easier to do it with G50.
