We have a Mazak SQT 18M Mark 2 with live tooling.The spindle bearings went out on it and we had to ship the entire spindle cartridge(spindle,motor,motor-jacket,actuator, ect.)to Kentucky for bearing replacement.
When it was returned, we had a Mazak tech install it for warrenty reasons.
All is good except the "C" axis is not at the same Home position as it was prior to rebuild.Now our problem is all of the prior progams(15 years worth) wont oreintate to their proper position and now we have to be careful with chuck jaw clearances and other issues.This will cause a lot of problems as you try to redo programs and know which have been done and which havent.
The tech who installed the spindle called and tried to find a solution to this but was unable to get one.
Is there a Parameter that can be changed to comp the amount of difference between the new home position and old home position in the "C" axis?
