603,980 active members*
2,404 visitors online*
Thread: pdf files
Results 1 to 3 of 3
    Jul 2005
    236
    pdf files
    If I save a file in a pdf, using .Pdf reader program can the document rights be enabled or do I need a .pdf writer program to do this.
    Jun 2005
    138
    Get CutePDF to create a "printer" that is actually the PDF writing program. I believe it allows you to set the document rights at that time.
    There are dozens of programs that will write and protect pdf files and you do NOT have to pay the outrageous Adobe prices. Google "pdf write" and take your choice.
    Feb 2012
    pdf file is a document not a video file,although I suppose no one has ever tried to use a vid as a pdf?
  1. Converting Illustrator files to Gcode files
    By acoop101 in forum Uncategorised CAM Discussion
    Last Post: 03-10-2023, 11:13 PM
  2. How can I convert .nc files into .nci files
    By AlphaD in forum Mastercam
    Last Post: 07-19-2009, 05:28 AM
  3. Replies: 2
    Last Post: 07-08-2009, 07:45 PM
  4. Convert files to Inventor files.
    By bartL in forum Autodesk
    Last Post: 02-04-2009, 06:38 AM
  5. convert .dnc files to .plt files.
    By feraldave in forum Uncategorised CAM Discussion
    Last Post: 10-13-2008, 10:48 AM
