603,415 active members*
2,623 visitors online*
Results 1 to 3 of 3
    Feb 2010
    71
    power supply hellp
    hello
    can somone help me and give me some points
    how strong power supply i need for 4 of this drivers Köprü Ba
    im using 3.5 A/phase stepper motors.
    im planing to use 36 V power supply but i dont know how much amps i need
    thanks
    Jan 2010
    2141
    From Support:
    The easiest factor in choosing a power supply is its current rating, which is based on your motor ratings. A motor control will always draw less than 2/3 of the motor’s rated current when it is parallel (or half-winding) connected and 1/3 of the motor’s rated current when it is series (or full-winding) connected. That is to say, a 6 amp per phase motor will require a 4 amp power supply when wired in parallel and a 2 amp power supply when wired in series. If multiple motors and drives are used, add the current requirements of each to arrive at the total power supply current rating.
    1943
    3.5 * 4 * 2/3 = 9.3A
  1. Replies: 15
    Last Post: 10-29-2013, 12:58 AM
  2. Power Supply/Power Cord Sizing for Four 850 oz-in Servos, One is Slaved
    By Plugger in forum CNC Machine Related Electronics
    Last Post: 03-11-2012, 05:52 AM
  3. FANUC Alpha Series power supply input power limits
    By tcom-frazzled in forum Uncategorised MetalWorking Machines
    Last Post: 01-17-2012, 06:07 PM
  4. Hellp
    By kalicas in forum Uncategorised CAM Discussion
    Last Post: 04-06-2007, 06:00 PM
  5. Power Supply from a computer power supply
    By jmytyk in forum CNC Machine Related Electronics
    Last Post: 01-11-2006, 09:56 PM
