603,813 active members*
2,888 visitors online*
Results 1 to 2 of 2
    Jan 2013
    Hardinge st-225 lathe
    We have a Hardinge st-225 lathe with fanuc 18-t controller. We can download prgms but cant upload via. RS-232 port. Machine parameters appear to be set correctly. They are as follows:
    0020=0
    100=00000000
    101=10000001
    102=0
    103=10
    110=00000000
    111=10000001
    Our laptop settings are as follows:
    Port=Com1
    Baud Rate=4800
    Data Bits=7
    Parity=none (must be set at none to download)
    Stop Bits=2
    Any help would be great
    May 2004
    4519
    Probably need more info on actual errors generated and software and steps used. Does your cable and computer work on another machine?
  1. Hardinge Lathe T42
    By outctrl in forum Hardinge Lathes
    Last Post: 03-01-2013, 05:08 AM
  2. CNC'ing a Hardinge 2nd OP DV-59 Lathe
    By Ken_Shea in forum Vertical Mill, Lathe Project Log
    Last Post: 08-31-2010, 02:43 PM
  3. EMCO LATHE VS. HARDINGE LATHE
    By Crashmaster in forum Uncategorised MetalWorking Machines
    Last Post: 03-04-2010, 05:33 PM
  4. CNC Hardinge Lathe
    By speerski in forum DNC Problems and Solutions
    Last Post: 07-08-2008, 01:43 PM
  5. DV-59 Hardinge Lathe going CNC
    By rrossey in forum Vertical Mill, Lathe Project Log
    Last Post: 04-11-2006, 02:55 AM
