587,481 active members*
3,213 visitors online*
IndustryArena Forum > MetalWorking Machines > Benchtop Machines > feed mills for my setup .Yay or nay ?
Results 1 to 3 of 3
    May 2011
    108
    I have debating getting a couple high feed mills.If you dont know what they are check them out at places like lakeshorecarbide.com . Basically mills made for high feed low depth of cut.
    Now heres the thing . I am running a small x2 hobby cnc mill and dont usually run high feedrates (usually top out at around 15ipm with the tools im using and being conservative) I do however use solidworks and HSMworks which is capable of making advanced HSM toolpaths.I also do a lot of pocketing around 1" deep in aluminum.
    Do you think its worth it to go with feed mills and run higher feedrates. I know most people using these mills are running in the hundreds of IPM but would i still benefit from using these mills on my smaller machine?
    Grizzly G0602-AXA QCTP<<< Soon to be CNC and 3PHA-VFD !
    7x14Lathe, X2cncmillG540 Solidworks,HSMworks,VcarvePro
    Feb 2006
    7063
    I can't imagine what you'd gain by that. Have you looked at the speed/feed recommendations for those things? You won't have the spindle RPM to run anywhere near the recommended SFPM, even in steel, and you won't have the rigidity to run high feedrate without over-shooting on every corner (which will probably break the inserts anyway). At the RPM and feeds you could realistically run, your MRR would probably be much less than what you'd get by properly using a far cheaper HSS endmill.
    Regards,
    Ray L.
    Jul 2006
    525
    Quote Originally Posted by chrisnis View Post
    Feedmills dont require any fancy tool path anyhow, the idea behind them being that you run them at as near to full engagement as possible, as quickly as possible, with low axial engagement.
    They're mostly used in Tool & Die work, where hard metals need 3d contours milled into large pieces of harder grades of steel.
    Also, they're generally terrible in aluminum, as aluminum cant handle the heat generated in such a thin chip-- nearly instantaneous BUE.
  1. Drip feed setup
    By AW-HCM in forum Uncategorised CAM Discussion
    Last Post: 02-14-2013, 11:11 AM
  2. Feed rates for small mills
    By littleCNCjohn in forum Benchtop Machines
    Last Post: 02-08-2011, 12:49 AM
  3. Backlash setup and feed???
    By zaebis in forum Mach Software (ArtSoft software)
    Last Post: 09-19-2010, 02:18 AM
  4. Replies: 2
    Last Post: 05-23-2007, 09:16 AM
  5. Small end mills feed speeds for 1mm steel
    By paulr4 in forum DIY CNC Router Table Machines
    Last Post: 08-13-2006, 01:29 PM
