587,941 active members*
3,216 visitors online*
IndustryArena Forum > CAM Software > Mastercam > mastercam posting segments of a circle
Results 1 to 6 of 6
    Dec 2008
    54
    Exclamation mastercam posting segments of a circle
    ok, lost here, posting with MasterCam X5, doing simple -Z-contour ramping routines. The post out file is segments of a circle making the post file very long and poor surface finish on the part? How do we change it to post I or J moves with a -Z- move on every full circle move?
    Any ideas
    May 2004
    4519
    Change your control definition file.
    Jul 2003
    263
    your filter settings should allow you to do that. use the 'refine toolpath' to control the length of your prog and the surface finish
    If you can ENVISION it I can make it
    Dec 2008
    54
    I changed the settings on the control manager and tried to refine my NC path nothing has changed? could it be something else?
    May 2004
    4519
    First, have you verified that you have full arcs/circles in your geometry? Or, do you have arc/circle segments?
    Second, in the Control Definition file for your machine, do you have Arc Breaks > Allow 360 degrees arc > Don't break arcs selected? Do you have Helix support > Only in XY plane or All planes supported selected? After you made changes, did you reload the machine in the Operations Manager > Machine Group > Properties > Files?
    Third, are you doing Contour > Ramp or are you doing Circle Mill > Helix or Contour with Lead in lead out Ramping?
    Pictures are worth 1000 words. See mine.
    Dec 2008
    54
    yes full circle arcs, everything is checked and reloaded as your picture shows. I am doing a contour ramp routine. posting segments?
  1. mastercam posting
    By peakeng in forum Torchmate
    Last Post: 08-25-2011, 04:57 PM
  2. Mastercam x5 Posting Help (HAAS)
    By NathanO in forum Mastercam
    Last Post: 07-18-2011, 10:07 AM
  3. Mastercam X3 not posting all operations
    By rcpilot82 in forum Mastercam
    Last Post: 11-18-2009, 01:59 PM
  4. RFQ: Circle segments
    By slick_rick in forum Employment Opportunity
    Last Post: 07-06-2007, 07:03 PM
  5. Mastercam posting problem
    By Redd in forum Mastercam
    Last Post: 02-08-2007, 08:24 PM
