603,799 active members*
2,834 visitors online*
IndustryArena Forum > Mechanical Engineering > Linear and Rotary Motion > 10 foot 1X1" 20* 24 DP rack and pinion
Results 1 to 14 of 14
    Dec 2005
    117
    Is there any interest in 10 foot pieces of gear rack? Another forum user and myself are about to buy some from Moore gear and it will reduce the price if the quantity is greater.
    My friend, is planning on having his rack drilled through the face every 12 inches. The holes will be drilled .25 inches off of the side so the pinion will have a little more than .5 inches to run on. The dimensions of the rack will be 1 inch square ,120 inches long.
    My table will use the same dimensions of rack only the holes will be drilled through the side of the gear .
    If there is any interest please let me know
    Dan
    Feb 2004
    1086
    I'm interested
    I'm planning on building a large machine soon, so I might be interested in this. I would need 3-4 pieces of 10 foot. Let me know what you've found out in terms of costing and performance on these. You can either post here, or send me an email at ahrenkj at yahoo dot com.
    Thanks,
    Ahren
    746
    1 inch square (1" face width) @ 24 DP sounds kind of beefy to me. Who makes a 1" wide 24 DP pinion gear.
    If it's not nailed down, it's mine.
    If I can pry it loose, it's not nailed down.
    May 2005
    1810
    I may be inerested, too. Please provide some details. Thanks.
    Scott
    Consistency is a good thing....unless you're consistently an idiot.
    Feb 2006
    24
    My company manufactures rack and pinions be glad to help you out let me know what you need.
    Dec 2005
    117
    I had 2 pieces quoted at 357 each
    4 pieces at 297 each delivered
    Those who are interested where do you need the holes drilled? Through the face near the edge, or through the side.
    The two orders, holes through the face , or holes through the side cannot be added together for the quote pricing. One or the other.
    pinion gears can be easily made with some gear stock or custom made by Moore Gear. They are sending me some quotes on gears.
    Hi can you please post some prices for gear racks? I believe 20 degree 24 pitch is the most common.
    Feb 2006
    24
    what ever Moore Gear quotes I will give you 25% off. If you can use gear stock for the pinion it would probably be the most cost efficient. If you need costom pinion I can do that too.
    Feb 2004
    1086
    Rack
    I can make my design work either way -- whatever is cheaper. If I had to decide, I'd say through the side to keep as much of the face as possible.
    Best regards,
    Ahren
    746
    McMaster-Carr has a 6' piece of 24 DP 14 1/2 degree 1/4" face undrilled gear rack for $50.83
    The drilled one is $44.42 but it is only 4' long.
    I have seen 4' by 8' CNC routers at wood working shows that only have 1/4" wide gears. Correct me if I'm wrong here but if you went to a larger face width then wouldn't you have to increase the presssure between the two to reduce backlash thereby creating more friction for the motor to overcome. There has to be a happy median somewhere here.
    Dec 2003
    24260
    On the surface, I would also think that appears to be a very wide face for 24DP, 1" is usually asociated with 12 to 10DP, at least from what I have used and have seen used commercial tables.
    A
    Albert E.
    Dec 2005
    117
    Quote Originally Posted by Bill Clark
    Can I please get your phone #
    Do you have the capabilites to make a 10 foot rack?
    [QUOTE=McMaster-Carr has a 6' piece of 24 DP 14 1/2 degree 1/4" face undrilled gear rack for $50.83
    I have seen 4' by 8' CNC routers at wood working shows that only have 1/4" wide gears. Correct me if I'm wrong here but if you went to a larger face width then wouldn't you have to increase the presssure between the two to reduce backlash thereby creating more friction for the motor to overcome. There has to be a happy median somewhere here.[/QUOTE]
    The 20 degree is superior to the 14.5 because it allows a smaller pinion without undercutting of the gears.
    Aug 2004
    155
    my strategy
    For what is worth... on my 10ft x-axis I bought a 4ft and 6ft piece. Using a belt sander you carefully remove enough material for the two adjoining sections to have equal amounts of material. I piece of the rack used for the y-axis or scrap is then used to test the fit.
    I failed to mention that my rack is glued into my rack using 614 Permatex adhesive.
    A one piece rack would be great but the price is a premium in my opinion.
    Dec 2005
    117
    Still interested
    Dan
    May 2005
    1810
    Austin -
    I previously expressed interest but unless these racks offer a substantially higher pitch accuracy than the shorter racks or have ground teeth, I have a lot of trouble justifying the inflated cost per foot. Having a continuous rack is not a huge priority as seams are really not a problem.
    Thanks for the info and thanks for the offer.
    Scott
