587,421 active members*
3,104 visitors online*
IndustryArena Forum > MetalWorking Machines > Bridgeport Machines > Bridgeport / Hardinge Mills > Boss 5 - Varispeed to V Pulley Conversion w/ VFD
Results 1 to 7 of 7
    Aug 2012
    113
    I have a Boss 5. Want to convert it to a vee pulley setup and be able to keep back gear as well as use the original spindle brake. The motor I have is the factory US Motors model that state RPM around 1710. I'm wondering how I should go about arranging the pulleys. Another guy did a similar setup and I was going to source parts like he did from Surplus Center. Tryingt ot figure out on pulley size at the moment. With 1710 RPM I would need something like a 2.47:1 ratio to maintain the orginal 4200 RPM.
    I would also like to be able to boost my spindle speed a little too...maybe up to 6k. I know I can overdrive the VFD as well. Will this motor handle it? I was thinking that using the pulleys initially to get me close to the stock 4200RPM and then go up from there with the VFD or am I missing something? I see a lot of guys did a 1:1 pulley arrangement. Wouldn't that only get me 1710 max?
    Dec 2003
    24223
    Re: Boss 5 - Varispeed to V Pulley Conversion w/ VFD
    Quote Originally Posted by jonesturf View Post
    Double if you run the motor up to 120Hz, same RPM as a 2 pole motor.
    Al.
    Albert E.
    Aug 2012
    113
    Two pole meaning a 3450 motor, right? Is it safe to run the stock motor at 120Hz?
    Dec 2003
    24223
    I have always run 4 pole motors at 120Hz, I figure most motor manufacturers make both 2 & 4 pole versions and use the same manuf techniques for both, balance, bearings etc.
    Al.
    Albert E.
    Aug 2012
    113
    So in order to get faster speeds I have to either get a different motor and start off faster (which I don't want to do), run the VFD up to 120 Hz, or work with pulleys. Any reason why everyone stays 1:1? I'm guessing loss in torque becomes an issue? Keeping back gear should help with that some though. Would running my pulleys to 3k with a ratio 1.75:1 ratio work and then pick any of the remaining speed up with the VFD or will I have torque issues with that at lower speeds?
    Forgot to mention my VFD is a Hitachi WJ200-22.
    Dec 2003
    24223
    I have a couple of XLO knee mills that I converted from varispeed to 1:1 direct, but these have a 6:1 GB also which can be switched in for the low rpm's.
    Al.
    Albert E.
    Aug 2012
    113
    I'm assuming those are with 3450 motors?
  1. Varispeed VFD conversion
    By DSE in forum Bridgeport / Hardinge Mills
    Last Post: 12-09-2014, 12:50 PM
  2. X2 pulley spindle conversion vs CNC speed control
    By xander18 in forum Benchtop Machines
    Last Post: 07-05-2011, 07:57 PM
  3. Boss pulley question
    By Sparky_NY in forum Bridgeport / Hardinge Mills
    Last Post: 10-26-2009, 01:07 PM
  4. BP conversion Pulley or Direct..I KNOW!!
    By Cartierusm in forum Bridgeport / Hardinge Mills
    Last Post: 03-05-2009, 06:28 PM
  5. Boss 6 Z-Axis Pulley Identification / Problem
    By snakebit95 in forum Bridgeport / Hardinge Mills
    Last Post: 09-04-2006, 09:25 PM
