Is it possible to connect a nema 34 stepper motor connected to dm860a driver to a serial servo controller. There is 3 connections on the servo controller which are Data, Ground, +5V. On the DM860A driver the only connections needed to move are (-)Pulse and (-)Direction. Here is the circuit from both. It looks like it can be done but im not an electronics expert. I dont know if the signals are compatible or not. Do i need a dual h bridge to run the stepper like a servo?
