587,997 active members*
1,614 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Mach Software (ArtSoft software) > Trying an xbox controller on my Mach3 setup... Maybe.
Results 1 to 5 of 5
    Aug 2005
    437
    I am interested in trying an xbox controller on my Mach3 setup. Not being game console savvy, I think I jumped the gun a bit. I ordered a cheap controller from ebay and the connector looks nothing like a usb connector…
    I did a little checking online and it looks like I can clip the connector off the controller and graft on a usb cable (taken from a old mouse) and I should be in business.
    Has anyone gone this rout? Or should I buy an adapter… Any recommendations?
    Thanks in advance.
    Attachment 186872
    Attachment 186876My connector looks like this.
    Deeds not words...
    VoltsAndBolts runs RC for the builder. http://www.voltsandboltsonline.com/ My Forum
    35538
    That's an XBox connector, and I have no idea if swapping it for a USB connector will work.
    Actually, looks like it might work.
    Tutorial: Replace your xbox controller cable with a USB cable ~ xbox m0dz
    Aug 2005
    437
    Well for the $9 I have invested I think I’ll give it a try.
    Let you know how it turns out.
    Deeds not words...
    Aug 2005
    437
    Ok so I did the mod to convert the Xbox connector to a USB.
    Here’s what you need.
    A cheap xbox controller.
    A USB cable with the end that plugs into your computer.
    Solder and Iron.
    Heat shrink to fit your wires and cable (or electrical tape)
    I had a unused USB cable that came with a printer. It will be my new connector for the game controller.
    I Cut the end that went to the printer off
    Attachment 186958
    Then I cut the connector from the controller.
    Attachment 186960
    Remove the cable jackets (note the yellow wire is not used)
    Attachment 186962
    Solder the wires. matching the colors.
    Attachment 186964
    Attachment 186966
    Cover with the sleeving
    Attachment 186968
    Shrink it down and your done!
    Attachment 186970
    I plug it in to my PC and it detected it as a Generic USB Hub. Now I need to load the drivers.
    I'll let you know how that goes.
    Note: Do this at your own risk.
    Deeds not words...
    Jun 2008
    562
    I have one of these mini keyboards on order for setup etc. I hope it works.
    71-Key 2.4 GHz Wireless Mini Keyboard with Touchpad w/LED HK Tide Technology Co.,Ltd. IPKW250FUSK
    Mike
  1. Xbox controller install on Mach3
    By zeeway in forum Mach Software (ArtSoft software)
    Last Post: Yesterday, 09:02 PM
  2. Xbox 360 controller on my Mikini
    By slowtwitch in forum Mikinimech
    Last Post: 07-03-2012, 01:25 PM
  3. XBOX 360 Controller
    By riche543 in forum Uncategorised CAD Discussion
    Last Post: 10-26-2011, 08:46 AM
  4. Xbox 360 controller
    By CATCH22 in forum Mach Wizards, Macros, & Addons
    Last Post: 08-24-2008, 12:04 AM
