587,372 active members*
3,417 visitors online*
Results 1 to 3 of 3
    Nov 2007
    250
    Jog Speed or rate
    Hello,
    I'm running mach .043.066 with the standard screen set 1024 for my milling machine. I've been trying to figure out how to slow down the jog speed or rate. The older version I was running some time back it was on the "program / run screen. I can't find it to save my life.
    Can someone give me a pointer on where it's located.
    Trying to use an edge-finder is hard to do at 80in/min... can't do it..
    Thanks for the helping hand.
    aj
    35538
    Hit the TAB key.
    Nov 2007
    250
    Thanks, I had total brain fade... Been using the plasma stuff from CandCNC and just totally forgot. Haven't worked on my mill for a good while and just dropped the ball I guess you could say... As simple as it is...
    Thanks for taking time. I just need a hint from time to time...
    Have a good day.
    aj
  1. Motor Speed and Feed Rate
    By arudson in forum Mach Mill
    Last Post: 05-27-2012, 02:41 PM
  2. spindle speed/feed rate
    By lamed in forum MetalWork Discussion
    Last Post: 06-03-2009, 12:25 PM
  3. Speed & Feed Rate?
    By dcis77 in forum Diemaking / Diecutting
    Last Post: 11-14-2008, 05:29 AM
  4. CNC feed rate and spindle speed
    By misc.garfield in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 01-30-2008, 12:20 AM
  5. Feed rate and Speedle speed for M4-.7 tap
    By chakaloso in forum Haas Mills
    Last Post: 09-20-2007, 09:52 PM
