603,890 active members*
3,993 visitors online*
IndustryArena Forum > MetalWorking Machines > Cincinnati CNC > Fanuc 18i Alarm 410 Error
Results 1 to 9 of 9
    Oct 2009
    3
    Hi, first post on here.
    Experiencing Alarm 410 Servo Alarm: X Axis - Excess Error on our FTV 850 Cincinnati. Manual says:
    "The position deviation value when the n-nth axis (axis 1-8) moves is larger than the set value. Refer to procedure of trouble shooting."
    That's not much help. Still waiting for Fanuc to call me back but I don't know where to start really. Could it be bad scales? Ballscrew?
    Jun 2009
    16
    Hi.
    Can you tunt the ballscrew bay hand?
    Feb 2009
    6028
    Position error
    Most likely scales have a dirty spot or your cables have gone bad. I can't remember the fixed table vertical layout too well, seems the motor and cable are stationary. If thats the case, cable wear may not be the issue. Check waycovers/guards for binding and give us the alarm code on the drive unit please.
    Oct 2009
    3
    This was the response I got from Fanuc on the problem:
    Alarm 410 indicates that the axis was out of position when it was supposed to be stopped. The error limit when stopped is in parameter 1829.
    This fault could be caused by an accelleration time constant being too short, or by something pushing the axis out of position.
    Try probing at a lower feedrate. If this makes the fault go away, then your axis may not be able to stop fast enough at the higher rate.
    GE Fanuc CNC Technical Support
    I have not yet made any changes, will let you know what happens when I do.
    I have not tried turning the ball screw by hand. I do not know how to do that since the brakes would be applied while I was in the machine.
    Jun 2009
    16
    8 out of 10 tims this i´s corst bay a bad bering's or ballscrew or a broken brack ore some thing bloking the axis.
    2 out of 10 its cabel or motor there is broken
    howe dos the alarm apir? hven powering op ore muving the axis?
    Jan 2010
    HI, I have a Puma 250M lathe with Fanuc 18T and get a 2028 alarm spindle rotation condition is not ready?? Any ideas? Thanks Jim 714 6121480
    Dec 2009
    3
    Post Re: Fanuc 18i Alarm 410 Error
    Fanuc controller 410 Z Axis error alarm when rotate axis anybody know solution.
    It si a problem of Z axis brake Or Ball screw
    Dec 2009
    3
    It may be problem of Brake
    Mar 2008
    352
    I agree with nitinmangle; this machine had voltage monitor relays in series with the brake circuit. This is documented in the Control Diagrams 9120xxxxy stamped on the serial plate.
    Check that the Z-Brake circuit is functioning properly first and that the Z-Motor fan is clean and running; blowing up. If it is; then most likely there is a mechanical bind in the ballscrew nut, thrust bearings or linear ways.
  1. fanuc 6m error 2 alarm led on
    By karthick in forum Fanuc
    Last Post: 01-24-2014, 05:16 AM
  2. Error 420 Y Servo, Fanuc 6T & 401 alarm too
    By mflux_gamblej in forum Uncategorised MetalWorking Machines
    Last Post: 02-11-2013, 05:33 AM
  3. Fanuc 18T -alarm 1003 t code error
    By imesol in forum Fanuc
    Last Post: 08-07-2012, 01:46 PM
  4. fanuc o-t alarm 1006 tool position error
    By Korellibopper in forum Fanuc
    Last Post: 11-18-2011, 06:48 PM
  5. Replies: 0
    Last Post: 12-04-2006, 04:49 PM
