603,858 active members*
7,788 visitors online*
Results 1 to 2 of 2
    Help with drivers
    Greetings,
    What do you think about these drivers they are digital ?
    Leadshine Technology Co., Ltd.
    Do you think this is compatibile with these motors 57 two-phase 3A
    Leading wires: 4 leading wire
    Shaft diameter: 8mm
    Shaft lenght: 25.5mm
    Motor dimension: 57*57*76mm
    Step Agle: 1.8+/-5%
    Insultion Resistant : 500V DC 100MΩ Min
    Insultion Strength: 50Hz 1Minute 500V Min
    Ambient Temperature: -20~+50 degree
    Temperature Rise: 80 Max.
    Radial Play: 0.02mm Max.
    End Play: 0.1-0.3mm
    Current/phase: 3.0A
    Voltage/phase: 3.6V
    Inductance/phase: 2.3+/-20%mH
    Resistance/phase: 1.1+/-10%ohm
    Holding torque: 1.5 N. M
    Regards
    Rok
    Jun 2007
    3738
    Re: Help with drivers
    Yes. OK. Set max current to 3A or less.
    With DM870 you will get better top speed, as can be run at higher voltage.
    M752 or M760 also a good choice.
    I have used these drivers, and they are easy to use.
  1. drivers
    By Rue0034 in forum Stepper Motors / Drives
    Last Post: 12-15-2011, 03:40 AM
  2. What drivers should I use with these........
    By MadeInTheShed in forum Stepper Motors / Drives
    Last Post: 07-22-2011, 04:52 AM
  3. IMS drivers vs. Gecko drivers
    By cnczoner in forum Stepper Motors / Drives
    Last Post: 04-05-2010, 04:50 AM
  4. drivers
    By oldman12 in forum Stepper Motors / Drives
    Last Post: 06-01-2008, 01:40 AM
  5. old drivers
    By erase42 in forum Xylotex
    Last Post: 10-23-2006, 11:08 AM
