587,322 active members*
3,327 visitors online*
    May 2014
    Cutting Lubricant
    I know I'm not to put a water base cutting lubricant into my swiss machine. But I was offered a mineral based product for machining at $585.00 a drum or canola based product at $710.00 a drum are they good prices?
    Sep 2011
    261
    Re: Cutting Lubricant
    Depending on your machine, you actually can use water soluble lube. Your have to have a sealed or pressurized guide bushing (sealed is self explanatory, pressurized means there is an air line that goes into the back of the bushing that creates positive pressure in the bushing housing).
    Also, the water soluble coolant requires twice the periodical maintenance.
    I don't know about the prices or oil you reference, but water soluble is a possibility.
    CNC Product Manager / Training Consultant
    Sep 2013
    37
    Blaser Vascomill 22. Easily some of the best stuff out there for cutting oil and it doesn't stain the machines. It's veggie oil so no petroleum waste to worry about, and it doesn't lose viscosity as easily as the petrol based lubes. So I can push on tools harder. I've got 10 Stars and they all run it.
    Feb 2009
    6028
    Hangstefer (sp?) Missle lube works well, higher flash point as well. More important than you might think especially if your doing titanium.
    Sent from my G-Tab Quantum using Tapatalk
  1. What's the best coolant/lubricant????
    By keith_k98 in forum MetalWork Discussion
    Last Post: 10-23-2008, 02:05 PM
  2. IH head lubricant
    By Runner4404spd in forum Charter Oak Automation Support Forum
    Last Post: 01-30-2008, 04:41 AM
  3. Dexron used as lubricant?
    By ranchak in forum Benchtop Machines
    Last Post: 11-25-2007, 09:28 PM
  4. Lubricant for ways
    Last Post: 11-24-2007, 04:08 PM
  5. Lubricant
    By joecnc2006 in forum Mechanical Calculations/Engineering Design
    Last Post: 11-26-2005, 08:35 AM
