587,482 active members*
3,420 visitors online*
IndustryArena Forum > MetalWorking Machines > Haas Machines > Haas Mills > Looking at a 1991 VF1 possible purchase
Results 1 to 5 of 5
    Apr 2004
    41
    Found a old 1991 VF1 locally ,its not in bad shape but does have a Com board problem
    But the machine works. Just have to enter the programming manually
    This will be my first CNC machine, after many attempts over the years.
    I was looking at getting a Tormach with all the bells and whistles, came to $14k
    I can get the HAAS for less than 1/2 , but with the problems.
    Should I go for it and get the HAAS or just keep looking... I do know there is a big difference between the two machines...
    I could always retrofit it with a new PC controller if the repairs end up exceeding what it would be worth.
    Thanks for any input.
    Aug 2004
    782
    Re: Looking at a 1991 VF1 possible purchase
    ? Why not buy the com board from haas and have them install it ?
    Less than 1000$ installed, I would have thought
    Jul 2008
    70
    I like the Haas fast machine and tech support is great. Just my 2 cents
    Mar 2010
    1852
    Thought about it, but it does not have Rigid Tap and the serial number is so old that it is not in the data base with Haas service. My first Haas was a new 1991 VF-1 and its serial number was about 1530, this one is 1012 or something. It is very old.
    You must have communications to use one of these machines. Entering code by hand is something I do all of the time, but not for longer major programs. It would not work for that.
    The machine is on East coast of Fl and service on the West coast, service trips would be costly. If you don't know how to repair these machines yourself, I would avoid it. And I would never try to convert to some PC based system.
    Mike
    Two Haas VF-2's, Haas HA5C, Haas HRT-9, Hardinge CHNC 1, Bother HS-300 Wire EDM, BobCAD V23, BobCAD V28
    Mar 2010
    1852
    Update, I guess he has revised the listing on eBay and it now says it has no doors! Believe me, you don't just make new ones.
  1. 1991 VF1 RS232 Problems
    By lovell110 in forum Haas Mills
    Last Post: 02-19-2020, 03:20 PM
  2. 1991 FMDC BP V2XT
    By Johns tool room in forum Bridgeport / Hardinge Mills
    Last Post: 07-14-2015, 02:04 PM
  3. Replies: 8
    Last Post: 02-27-2014, 12:41 AM
  4. 1991 QT.15N
    By dcchip in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 01-08-2011, 10:24 PM
  5. Help with 1991 VF1?
    By david bright in forum Haas Mills
    Last Post: 07-20-2007, 12:27 PM
