587,986 active members*
5,108 visitors online*
IndustryArena Forum > Machinery Manual, Brochure / Photo Archives > Machinery Manuals / Brochures > Electrical wiring diagrams / schematics for Okuma LB25 urgently needed.
Results 1 to 3 of 3
    Sep 2013
    14
    Hi guys!
    I´m in desperate need of electrical documentation on Okuma LB25.
    The machine instantly blows the main (grid) fuses when trying to start the spindle.
    The spindle drive is:
    VAC-Drive unit type A
    D22-A
    15/11 Kw
    LB25
    Machine serial is 6311.0030
    Main control (i dont remember if its OSP 3000 or OSP 5000) runs fine, so does axis servo´s and motors.
    If some one know how the spindle motor is interconnected with the drive and how the motor internal wiring is arranged (there is six power wires between motor and drive) this would be most helpful, so would info. on the expected values of Ohm measurement on the disconnected motor, as my first task is to determine wether its the drive or the motor that´s gone bad..
    Regards
    /Thomas
    Re: Electrical wiring diagrams / schematics for Okuma LB25 urgently needed.
    Usually on the plate also says the number of the electrical manual as well.
    Send me an email, I might be able to help you
    [email protected]
    Quote Originally Posted by Thamaz View Post
    Hi guys!
    D22-A
    15/11 Kw
    LB25
    Regards
    /Thomas
    Feb 2009
    6028
    Green machine or white? With 6 wires, sounds like a newer one with double wound motor. The leads would connect to a contactor set, not directly to the drive. Either way, I highly doubt its the motor. I have prints for a LB25 with 7000.
    Sent from my G-Tab Quantum using Tapatalk
  1. electrical diagrams
    By rjmachine in forum Kitamura
    Last Post: 06-26-2021, 04:36 PM
  2. Amada Pega 244 electrical circuit diagrams needed
    By Ramage in forum Machinery Manuals / Brochures
    Last Post: 06-29-2016, 07:58 PM
  3. Okuma LB25II OSP7000 Wiring Diagrams
    By chenzen666 in forum Okuma
    Last Post: 08-11-2009, 11:16 PM
  4. Electrical Panel & Router Wiring Diagrams
    By Santa Fe Al in forum CNC Machine Related Electronics
    Last Post: 03-26-2009, 01:51 AM
  5. Need Okuma LB25 12station Turret Parts
    By Drake75 in forum Want To Buy...Need help!
    Last Post: 03-04-2008, 04:50 PM
