603,907 active members*
4,537 visitors online*
Results 1 to 5 of 5
    May 2014
    8
    Puma 250BX Turret timing
    I replaced the O-rings in the turret drive control valve, they were leaking and causing the turret to free wheel on tool change command, Now I'm having problems getting the turret timing right.
    The turret out/in switch is ok as well as the limit switch. When I do a manual tool change, the turret moves out, rotates to desired tool, moves back in to within almost 1/4" or just before it makes the turret close switch and stops............. Anyone have any ideas? Help is much appreciated.
    Feb 2013
    796
    Re: Puma 250BX Turret timing
    See attached:
    Press E-stop and then see if you can tighten the lock nuts (NUT, LOCK - items 290&360) further.
    If the lock nuts are tightened while the hydraulics are active, a "tight feel" will not be tight enough.
    Attached Thumbnails Attached Thumbnails Puma 250 Hydraulic Turret Assembly.pdf
    Doosan Service Technician
    [email protected] O:973-618-2461 M:973-803-9479
    May 2014
    8
    Thanks dhardt, problem sovled. We are back up and running smoothly.
    Feb 2013
    796
    For others that are reading this thread, looking for a solution to a similar issue...Was the problem resolved by the mentioned procedure, or was it something else?
    (Posting the resolution procedure here could benefit another user who is down.)
    May 2014
    8
    Your suggestion solved the problem, Thanks again.
  1. Turret punch timing
    By Rad80 in forum MetalWork Discussion
    Last Post: 12-03-2024, 04:38 PM
  2. Puma 250BX encoder problem
    By samfugate in forum Daewoo/Doosan
    Last Post: 05-14-2014, 01:14 PM
  3. timing the turret
    By allmotormatt in forum Haas Lathes
    Last Post: 05-09-2013, 12:19 PM
  4. Turret and servo/encoder timing off
    By redman_80us in forum Fanuc
    Last Post: 05-09-2013, 03:18 AM
