588,137 active members*
5,934 visitors online*
Results 1 to 3 of 3
    Apr 2015
    In site lineboring
    We have a somewhat worn out bronze bushing on our sailboat.
    (The upper rudder bearing)
    Innerdiameter ca 60 mm and outer diameter is a bit over 80mm.
    The bushing is molded into the hull and impossible to remove without damaging the deck.
    I would like to linebore out the upper part of the bronze bushing to be able to insert a Delrin/PON Bushing with the correct size into the bronze bushing without removing it.
    Is this possible and what tools do I need to do this in site? Preferrably with an ordinary drill or milling machine.
    There is a bit of space beneath the bearing inside of the hull, so operations from both sides of the bearing is possible.
    Jul 2007
    1602
    Re: In site lineboring
    It looks pretty straightforward. The key will be keeping things rigid enough. Is there a lower rudder bearing you can use as a guide?
    Have you considered other options like Moglice or Babbitt?
    bob
    Apr 2015
    What is Moglice & Babbit?
    There is a lower rudder bearing with the same inner diameter about 1 meter below the upper one.
    //Kjelle
    Quote Originally Posted by rowbare View Post
    bob
  1. New BoB Site ? ? ?
    By jrmach in forum BobCad-Cam
    Last Post: 03-09-2013, 04:13 AM
  2. New web site
    By andre-dolphin in forum Dolphin CAD/CAM
    Last Post: 01-06-2009, 02:08 AM
  3. How about this Site?
    By edgarinventor in forum MetalWork Discussion
    Last Post: 08-02-2008, 01:23 PM
  4. New to the site
    By EdgeCrusher in forum MetalWork Discussion
    Last Post: 08-03-2007, 03:16 AM
